i read all of this and still don't have a clear answer. i probably missed it. so will any rim (in skyline stud pattern)17 or 18 inch diameter, 9 inches wide with a +30 offset fit?? or do u need a different width and offset front to rear. id like to have the same width and off set all round i can rotate the tires, but if i cant then i wont worry about it. or should i just use a narrower rim like 8.5 or 8 inch
That width and offset should be fine, Ray. R34 GTR wheels are 9" wide and are a pretty common fitment on Stageas.
If you've got an AWD Stagea, make sure you keep the same width wheels front and rear, or AT LEAST have the same rolling diameter at each end. That way, you won't stuff up your transfer case due to different wheel speeds at each axle. And, as you've already mentioned, you can rotate tyres without any hassles.
yes it is AWD. im planing on running 245s all round. height profile will depend on if i get 17 or 18 inch rims.
Edit: i found a set of wheels i like they are front 18X8 and rear 18X9 with an Offset of Front 35,Rear 38. will these fit?? im guessing they wont.
Edited by Raysboostin
  • 3 weeks later...
Im running 18x8.5 +18 all round on my S1 stagea with 225 tyres
Im not sure if theres any spacers etc as I only got the car last week so havnt had a chance to check it out.. but the rear seems to have a wider track than the front, or is this normal.
the front can actually take a larger wheel/.lower offset than the rear
I had to roll my fenders quite a bit ot get an 18x9+20 to fit well.
i haev an 18x9 -5 (wiht a 25mm spacer total of -5) on the front with a roll as well, but it fits the same as the rear
its a skyling thing, all skylines can have a lower offset in the front
hey mate did you have any pics? would be keen to see how that front looks ;)
+30 in the rear shouild be fine if your not to low
I had to pull the rear fenders a bit to get the 9 +20s to fit without a huge amount of camber
you can really fit anything you want on it. i had an 18x10+20 wheel on there, but i didnt pull the fenders far enough, so it hit the strut becuase of the amount of camber i was running.
  • 4 weeks later...
  • 4 weeks later...
  • 1 month later...
Digging up an old thread here... but could somebody please tell me what offset I need for 17" x 8"? Car is a Series 2 RS-Four V (auto)...
I have sussed that the PCD is 5 x 114.3, the rim needs to be 17 x 8 to run a 245/45 profile tyre to match rolling radius, now I just need to know what offset to use. I think the closest match in the wheels I have in mind are +40... if I go to 8.5" width I can get down to a +35.
Thanks,
DaveB
  • 3 months later...
Hi all,
Thinking of putting these wheels on my stag: post-40162-1210843777_thumb.jpg
They are 17" Lenso's
I think they look pretty good and will suit my stag nicely pl,us cant really go wrong for $300!
My question is they currently have tyres on them are 215 / 45 / r17 (no tread), my current tyres are 215 / 50 / r17.... Will they fit these new rims?
Cheers
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
