s13-rb26
rebuilt rb26.
forged pistons
argo rods
prep block etc
stock head
hks 272 cams
unkown cam gears
hks valve springs
garrett 3582r
hypertune plenum
os giken 1-3 gear set
20psi=497hpatw............oh controlled by haltec e11v2....this tune was death in the s13 so now is running stock cams and only 16psi which saw 427hp now much beta on the street and minus the shit idle from the 272s......no scanner atm..
1994 R32 VspecII
Apexi Dual pods
Apexi 3.5in dumps back pipe
HKS hard piping kit
Possibly big injectors
Possibly Z32's
and a Question mark over the Turbo's (Expect them to be standard but it turns out they hold 20psi VERY well... but will not go back there until we know about them)
Running on 7psi
140kw at all four did it 4 runs in a row and all lines are pretty much touching...
Have since found out how to get it on 14psi and 20... (Turn the boost controller on... Fkin idiot)
1989 R32 GTR Stock internals.
HKS GT-SS turbos.
Tomei Expreme manifolds and dumps.
Hand made front pipe (Dual 3" into 3.5" then metal cat)
Apexi ECU Apexi boost control.
Nismo fuel pump and reg Sard 700cc
Stock airflows and intercooler.
Made 301rwkw @17psi on Unigroup dyno
94 R32 GTR
Power FC
BB N1 Turbos
15psi actuators
700cc Injectors
Walbro Fuel Pump
HDI 100mm intercooler
RB20 AFM's
JJR Coils
Standard Airbox with HKS panel filter
HDI boost controller
otherwise standard
(Looks stock as a rock, painted cooler black to match standard)
245rwkw @ 14psi (low boost setting)
303rwkw @ 20psi (hi boost setting)
485RWHP 1993 GTR @ 110 Ramp Rate
Arias 87mm Forged Pistons
Argo Conrods
N1 Water Pump
Genuine Nissan R33 GTR Crank
Jun High Volume Oil Pump
ATI Harmonic Balancer
GReddy Light Weight Pulley Kit
Trust Sump Extension, baffle and pickup
HKS 1.6mm head gasket
Jun 272 10.5mm Cams
Jun Valve Guides
Jun Valve Springs
Splitfire Coilpacks
Sard Dual Entry Fuel Rail
Sard 800cc Injectors
Sard Fuel Pressure Regulator
Bosch 044 pump mounted internally
Garrett GT2860R-5 Turbos (Housings ceramic coated by CIC)
6-Boost steam pipe manifold (Low mount, ceramic coated by CIC)
Braided Oil and Water turbo lines with Speedflow fittings
Trust Extension Split Dumps (Ceramic coated by CIC)
Trust 90mm Front Pipe (Ceramic coated by CIC)
Apexi N1 90mm Cat back
Motor/turbos can go higher but is limited by street fuel....
  • 4 weeks later...
r32 gtr
jun 2.7
trust head
ppg box
hypertune plenum and t/b
t88 38gk kit
motec m800
etc etc etc
470awkw @ 20psi
?? @ 25psi to come tomoro
car made 563awkw @ 24 psi BP98, 470 was the old tune, 2bar race tune comin..
GT block
Power FC
Tomei procam 270 @ 10.25
Tomei stroker
HKS GT RS's
Kakimoto full mega N1 cat back
X force 3.5 inch cat
HKS dumps and front pipes
Tomei manifolds
800 CC sard injectors
Nismo fuel pump
HKS Twin spark
STI harmonic balancer
Stock airbox with Nismo panel filter
Blitz duel solenoid boost controller
Nismo plenum
Toda cam gears (intake set at 12 degree advance and exhaust roughly 0)
Tuned on BP ultimate
Coils were breaking down with anymore then 21 psi. Will go back with a fresh set and more boost. Setup the car for as much area under the curve as possible.power_curve.JPG
279 awkw, dyno dynamics dyno, tuned by Glen at ESP racing (Queanbeyan)
HKS 2530's (yeah, original, I know)
Cooling pro 100mm tube-and-fin intercooler (Just jap) stock plumbing
split dumps, bigger fronts, metalcat 200 cell cat, HKS zorst
40mm cooling pro radiator
Tomei 276 lph fuel pump set up to run 100% voltage
Sard 1000cc injectors
apexi twin pod filters
Unopened top and bottom end, including factory cams etc.
Glen did a great job, starts, cold idles, idles as good or better than factory, and improved fuel consumption.
PowerFC
Garrett 2860-5's
700cc injectors
JJR cam gears
Nismo AFM's
Nismo fuel pump
Splitfire Coilpacks
Standard ported manifolds
Blitz Dual SBC Boost Controller
Total power 309.0rwkw @16psi. Had issues with boost controller, could not physically set it higher than 16psi, wanted to push for 18psi, but that's sorted now and will do a retune soon
'89 R32 GTR
Rebuilt Motor:
CP Forged Pistons
Tomei Sump Baffle
Tomei Thicker Head Gasket
New R33 GTR Crank
ACL Race Bearings
Recon Head
Garrett 2860-5's
3in Exhaust w/Mines dump pipes
Trust Airnix Pods
Stock ECU
Stock Injectors
Stock Fuel Pump
Peak Power 250.0rwkw @ 13psi, kept it to waste gate tension as the motor has just been run in. Will be going for more soon, but a punchy 250rwkw is enough for now
Dyno_Results__1st_run____13psi.pdf
HKS GT-SS turbos.
interesting to compare this to my old GTR. very similar mods.
mine was:
R32 GTR with R33 GTR brand new crate motor
Head porting by prime garage
tomei expreme manifolds
tomei expreme dump pipes
tomei 600cc injectors
nismo fuel pump
nismo air flow meters
Tomei pon cams 260/260 9.15mm
trust full piping kit inc intake etc.
HKS GT-SS turbos
Apexi Power FC
trust profec B II
trust intercooler
front pipes and 3.5 inch exhaust
made 303kw at the same boost as you 17psi and on a set of R34 GTR 18inch wheels with average tyres ran a 11.7 @ 120mph with lots more to go in driver and car!
BUT check out the response difference.
at 4,000rpm you are making about 105kw at the same RPM I'm making 160kw
at 4,400rpm you are making about 160kw and I'm making 210kw
at 5,000rpm you are making about 215kw and I'm making 250kw.
at 5,600 rpm you are making about 250kw and I'm making about 275kw (you are starting to catch up)
at 6,200 rpm you are making dead on 280kw and I'm making about 295kw (getting even closer)
and at 6,800 rpm you are making about 295kw and I'm making my peak of 303kw (very close now)
at 7,400rpm we are just about dead even on 300kw. Yours revs a bit harder. mine was a fresh engine just run in so we kept revs down under 8,000rpm.
we both have very similar set-ups and very similar AFRs and boost levels. what does your boost curve look like?
I would have thought mine may even suffer a little in response as I have a 1.2mm tomei head gasket which lowers compression a little.
the only real differences are I have mild cams and headwork. which seems to have done it's job. :laugh:
my graph:
there may even be more to be gained from yours response wise with more tuning (timing) and maybe some cams? for a very similar set-up it does give away a lot in the mid-range. as much as 50kw at the wheels in some points.
Righto here was the work done to my old 32R she made 350hp on 12 psi on stock turbos and cams so was pretty stoked with those figures
Engine
-R33 rb26
-block bored and honed using torque plate
-polished and chanfered crank
-fully reconditioned head
-light port and polish
-three angled valves
-20thou wiseco pistons
-wiseco rings
-standard rods but have been prepped and have arp rod bolts
-acl main bearings
-acl rod bearings
-arp head studs
-N1 oil pump
-N1 water pump
-Cometic 1.2mm head gasket
-nissan gaskets and seals
-Gates blue timing belt
-Gates belts
-700cc sard injectors
-walbro 500hp pump
-splitfire coilpacks
-exedy twin plate clutch
-catback kakimoto exhaust
GTR34
2*T517Z
800cc injector
AVCR
PFC+Z32AFM
Nismo intercooler
Nismo oil pump
Nismo fuel pump (its limited the power, need better fuel system for more power)
Nismo full 3" exhaust + cat(need get 4")
Nismo piping
Apexi super suction kit
turbo smart fuel reg
tomei cam gear in&ex
tomei camshaft both 256 i think.
forged piston, rods
1 bar 270kw
1.3 bar 312kw
new result:
385.9hp on 1.1bar
463.2hp on 1.45bar
mods update:
94mm trust catback
2*044 pump 3L surge tank
sard fuel reg
tomei fuel rail
(ps: I have read some old topic, someone said 517Z's make 155kws at 128km/h, my t517z is a lot better than this,and i'm sure this is not a highread dyno)
Edited by Nosure
dyno chart... just had a bottom end refresh... mods include
2x Trust T517Z-8cm2 Turbos
Apexi Super Suction Intake Kit
80mm AFM's
Trust 600x290x115 Intercooler
HKS Intercooler Hard Piping Kit
HKS Stainless Dump Pipes
Apexi GT-Spec Stainless System
Apexi Power-FC ECU + Hand Controller
Blitz SBC-iD Boost Controller
HKS 680cc Injectors
Bosch 044 Fuel Pump
Tomei 87mm Forged Pistons
Std. Rods with Tomei uprated Rod bolts
Tomei 260in/260ex, 10.8mm lift, Camshafts
Tomei Adjustable Cam Pulleys
Tomei B-Type Valve Springs & Retainers
Tomei Uprated Lifters
Nissan N1 Oil Pump and Water Pump
HKS 1.2mm Stopper Type Metal Head Gasket
Custom Sump Extension and Baffles
Custom Oil Catch Can
Dyno @ 20psi... rev limit 8,500rpm
Got my car off the dyno today, went from twin 2835's to a single GT35R. Car is 100% better to drive now, so so so much better.
Specs:
N1 Block
TOMEI Forged 86.5mm Pistons
Pauter Forged Rods
TOMEI Procams (270 x 10.8mm)
JUN High Flow Oil Pump
Garrett GT35R (.82 T4 rear)
Ebay manifold
PWR 50mm Wastegate
2x 044 Bosch fuel pumps (external)
Greddy Fuel Rail
Sard fuel pressure regulator
APEX'i Power FC (non d-jet)
Nismo Fuel Pump (pickup)
Denso 700cc Injectors
Spitfire coils
557rwhp @ 1.8bar (415rwkw @ 26psi). Have revved it to 8800rpm, however its predominately a track car, so we've brought the limiter down to reduce the wear on the motor. Made ~500hp all the way to the 8800rpm limiter.
Edited by Brockas
Update, just added 3.5 inch Metal Cat into the exhaust system and Split fire Coilpacks
Other mods below:
* HKS Front pipe, HKS rear pipe with Hi Power Muffler
* Garrett 2860R-5 Turbos
* HKS SPL full piping kit with HKS super power flow pods
* Nismo Fuel Pump
* Turbosmart fuel regulator with pressure gauge
* Hypertune Billet fuel rail
* Siemens 610cc Injectors
* OS Giken Cam gears
* Nismo twin plate clutch
* Vipec V44 ECU
* Tech Edge Wideband AFR controller
* HKS EVC6
ALL WHEEL HORSEPOWER
Bit of valve float at high RPM/Boost (see grey line) May have made another 10 HP or so otherwise
UPDATED:
New computer
RB26DETT
Autronic SM4
Garrett GT2560R 300HP Ball Bearing Turbochargers
750cc Injectors
Tomei Pon Cams
Cam Gears
HKS Valve springs
Tomei Oil Restrictor
HKS Sump Baffle
MAP Sensors
Cometic MLS head gasket
Machined and ported head
N1 Water Pump
N1 Oil Pump
Wiseco Forged Pistons
Eagle Con Rods
ARP Heat Stud Kit
ARP Main Stud Kit
Ogura Racing Clutch Twin Plate
Bosch 044 Fuel Pump
Sard Fuel Reg
Splitfire Coils
356.4kw atw @ 24psi
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
