Got to thinking the other day - I wonder if you would do a purpose built , road registered , track day car for like under $8,000 total - ready to race.
Must be quick enough to have fun in - must handle well and brake well. Also must be fairly economical on consumables and repairs (if required)
So I put my thinking cap on and came up with this.
Suzuki swift GTI - you can get them for about $4,000 - $5,000
Rip out everything you don't need - make it as light as possible.
Upgrade shocks and springs - get allignment, camber and castor done especially for track work - say $1500
Chuck away standard rims and tyres - Run lightweight wheels and semi slicks - $1500
Upgrade (with bigger) front discs and callipers $1000.
I reckon that might be a goer. Cheap , fun track car.
Any other opinions for a good, cheap, fun track car ?
Cheers,
https://www.sau.com.au/forums/topic/129989-cheapest-most-fun-track-day-car/
  • Replies 79
pulsar for $2k.. CA18det sho'ed in for another $3k or so..
couple of $k on suspension. Would go pretty well (pushing 200kw) and weigh around 1000kg
I think in the 1.3L you'd be lacking in torque on the GTI, and they are quite overpriced for an old car.
Any old commo you could probably buy for $1-2k and spend another $5k on racing mods, and might be ok.
MK 1 Escort. You can buy a log booked, 2L caged car for the money you are looking to spend. At abour 800kgs and aboiut 160hp from a well sorted 2L Pinto they are respectable performers. You can always throw a CA18DET in there, but they just throw more weight in the things
does it have to be road registered? cant u have an econobox for daily duties? this owuld open up your options enourmously for a track car. althoough you then need to budget for towing etc.
non registered track cars:
HQ/VN/VP/EA race cars arent all taht dear i dont think
race only RX7/skyline/WRX
F3000/open wheeler thingos
and then there always bikes if u just wanna go fast real cheap, but there is the downside of being like 30 times more likely of being killed on the roads....
cortina with 250 crossflow 4.1L $1-2 grand they weigh about 1.1 tonne
turbo $3 grand
and some decent tyres. great car to drive and do some doeys in
With $8k
Mini Clubman+Mods
S1/2/3 RX7 (I doubt youd get a track worthy FC for below $8k)
Ford Escort+Mods
Gemini+Mods
Mazda 808 with a rotary conversion (RX3 setup)
Toyota Corrolla, the square early 80's one. Conversion and mods
Doubt you'd get a track worthy CA18DET S13....
Commodore might be a good thing.
R31 - ha ha ha -
I wouldn't want to trailer a car - too much hassle then there is what do I trailer it with ?
Escort might be good - RWD if def a better option.
Would want to keep the car nice and light - so no Hq, Commodore etc
I've seen some of those Honda's you are talking about Bob - They are quick circuit cars.
The Swifts did OK at Bathurst - for their category. Make them light enough and the 1.3 wouldn't matter , I'd guess.
Just did a search on Carsales.com - no Escorts there. You'd prolly need to be in the know to get a race prepped one hey.
Saw a first gen GTI for $2000 (had a 2nd gen motor in it) - Spend $2000 on the car then $4000 in mods - got to be a good circuit car for $6K......
Keep pthe suggestions coming ! It's interesting !
Mini - ?? Hmm - think a swift would kick it.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
