Hi um i dunno if this helps but i had 3 1/2" catback then i gat the epa notice, so i had a good look at what i had under the car and found a Flange plate just under the the rear axel that had the cannon attatched, so i went to an exhaust place and got them to make the back bit out of 2 1/2" with a nice big quite muffler. It cost me 140 but at least they done what i wanted other places wanted me to replace the lot for 350!. Anyway the test showed a nice quiet 80 db.
I noticed that i had no power, no noise and no fun. so as soon as i passed the test i chucked the cannon back on all better now, and when i get another notice probably next week i already have the solution!
:D
i got tested at 100dB with my Trust Power Extreme Cat back, Blitz Front pipe, and Trust Dump... went down to the local exhaust shop and got a weasly bit of 2" from the rear flange with a fairly pissy round standard muffler and they re-tested it at 85dB! only cost about $120 and very suprisingly the car doesnt seem to of lost any noticable power!! however its quiter than a standard ford laser! :D
Also, aparently Silencer plugs WILL NOT PASS according to the EPA noise tester i went to! Mine only brought the noise down to 94dB anyway but the guy said even if they're welded in they're not allowed to pass them any more! :ninja:
Does the EPA actually get the car on a hoist or take it for a drive during a full emissions test??? (obviously this is different to getting a RWC)
yeah i the fmic isnt stock, i undersatnd you cant have both. i just thought it was wierd how quick he let me go, and i also thought that you got caneried when you got a epa???
they dont need to stick around long.... once they've got ur rego they already know where to send the letter!
probly just checking if the driver was also the owner! :D
This should be an easy one, but a quick question, if I buy a car with an epa on it and no rego in victoria, can I get a day permit to get it up to Canberra? or will I need to trailer it up? Car has an epa on it for excessive noise.
If the date on the notice has passed the cars rego will be suspended. That mean that in VIC you can;t get a day/unreg vehicle permit.
As all the state systems are hooked up now I would be almost certain you would not be able to get a permit to drive the car in the ACT. So you will have to trailer it up.
  • 3 weeks later...
Thanks for the info stolen_s15
It might be easier if I just post up the car's mods and if anyone can tell me which is defectable, apart from boost controller. Couldn't find any info on whether other items eg., turbo timer defectable.
HKS split dumps
HKS front pipe
HKS hipower catback (legal noise I think)
HKS adj cam gears (IN/EX)
HKS timing belt with Trust clear cover
Apexi pod air filter
Turbo timer
Nismo twin plate clutch (super coppermix)
Cheers. Much appreciated.
Clutch - No issues
Air pod - only okay if you dont have a front mount added on (GTR excepted)
Timing belt - No issues (cant see any problem with clear cover)
Catback - Legal if it meets both noise and emissions levels.
Others, no idea, but I think they are all okay.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
