Hi um i dunno if this helps but i had 3 1/2" catback then i gat the epa notice, so i had a good look at what i had under the car and found a Flange plate just under the the rear axel that had the cannon attatched, so i went to an exhaust place and got them to make the back bit out of 2 1/2" with a nice big quite muffler. It cost me 140 but at least they done what i wanted other places wanted me to replace the lot for 350!. Anyway the test showed a nice quiet 80 db.
I noticed that i had no power, no noise and no fun. so as soon as i passed the test i chucked the cannon back on all better now, and when i get another notice probably next week i already have the solution!
:D
i got tested at 100dB with my Trust Power Extreme Cat back, Blitz Front pipe, and Trust Dump... went down to the local exhaust shop and got a weasly bit of 2" from the rear flange with a fairly pissy round standard muffler and they re-tested it at 85dB! only cost about $120 and very suprisingly the car doesnt seem to of lost any noticable power!! however its quiter than a standard ford laser! :D
Also, aparently Silencer plugs WILL NOT PASS according to the EPA noise tester i went to! Mine only brought the noise down to 94dB anyway but the guy said even if they're welded in they're not allowed to pass them any more! :ninja:
Does the EPA actually get the car on a hoist or take it for a drive during a full emissions test??? (obviously this is different to getting a RWC)
yeah i the fmic isnt stock, i undersatnd you cant have both. i just thought it was wierd how quick he let me go, and i also thought that you got caneried when you got a epa???
they dont need to stick around long.... once they've got ur rego they already know where to send the letter!
probly just checking if the driver was also the owner! :D
This should be an easy one, but a quick question, if I buy a car with an epa on it and no rego in victoria, can I get a day permit to get it up to Canberra? or will I need to trailer it up? Car has an epa on it for excessive noise.
If the date on the notice has passed the cars rego will be suspended. That mean that in VIC you can;t get a day/unreg vehicle permit.
As all the state systems are hooked up now I would be almost certain you would not be able to get a permit to drive the car in the ACT. So you will have to trailer it up.
  • 3 weeks later...
Thanks for the info stolen_s15
It might be easier if I just post up the car's mods and if anyone can tell me which is defectable, apart from boost controller. Couldn't find any info on whether other items eg., turbo timer defectable.
HKS split dumps
HKS front pipe
HKS hipower catback (legal noise I think)
HKS adj cam gears (IN/EX)
HKS timing belt with Trust clear cover
Apexi pod air filter
Turbo timer
Nismo twin plate clutch (super coppermix)
Cheers. Much appreciated.
Clutch - No issues
Air pod - only okay if you dont have a front mount added on (GTR excepted)
Timing belt - No issues (cant see any problem with clear cover)
Catback - Legal if it meets both noise and emissions levels.
Others, no idea, but I think they are all okay.
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
