Yeah basically.
And if you fail the test - you've done your dough and have to pay the fee again. I wish it was just a simple IM-240 test like NSW (a 15min job), rather than full ADR testing we VICs have to deal with
Yer i was lucky enough when i took my car there guy just said come back again, didnt take my money which was handy so i didnt need 2 tests lol
  • 3 weeks later...
just wondering whats the deal with drilling small-ish ?
thinking about drilling two 3cm or so holes where the battery tray/ ripples start and where the tubs finish to mount a bigger oil cooler... if i plan to
thanks
thanks
If the car has ABS - it's a flat no-no.
If the car is non-ABS, as long as you reinforce the underside of the holes, it's no problem.
I just got a RWC report done on my R33 and it states "Exhaust system cat back too low" which I don't believe to be true as I've got standard springs and the car passed the last RWC to which I haven't changed anything since. I questioned the RWC workshop and they said I would need to produce evidence of this.
So I called Vic Roads to ask them if they could run the height clearance trolley under my car and issue a report to which they said they can only do this for defected cars. I then asked the operator what the required clearance is but she didn't know exactly, but said to use the height of a 'Coke can' (130mm) as a guide.
I did a bit of digging around and according to Vic Roads VSI 8 under Section 4. Ground Clearance:
The ground clearance of a vehicle measured from a horizontal road surface to any point
on the underside of the vehicle except the tyres, wheels, wheel hubs and brake backing plates
shall, with the vehicle in its loaded state as specified by the manufacturer, be not less than:
  • for any point in the width of the vehicle which is within one metre fore and aft of any axle, 100mm;
  • for the mid-point between any two consecutive axles, the dimension in millimetres obtained by multiplying the distance in metres between those two axles by 33.33.
I checked the ground clearance and the lowest point on my car (cat back) is 105mm.
Second to this, I calculated the mid-point clearance by multiplying the distance between the axles (2.8m) by 33.33, which equals 93.324mm
Therefore, by my calculations I am within the legal ground clearance requirement. Or is there something I am missing???
Firstly good on you for actually going to the effort and checking the Vicroads information and giving them a call. it's refreshing to see this being done! :yes:
The last time I checked, the test is done with the car having the driver and a passenger and 30kg of luggage. Perhaps this will change your readings and provide you with what the RWC place got?
Cheers. I'm trying to be as thorough as possible as the workshop I went to has come under new management since I last visited and they come across as dodgy; so I'd like to have the facts on hand.
A few years ago I got a yellow canary for the car being too low (the car passed Vic Roads new import inspection on the same springs!). So I had to get a RWC which included putting on standard height springs and take it to Vic Roads to get the height checked. The Vic Roads inspector simply had me sit in the car (no passenger) and ran a height check trolley under the car & it passed. I haven't changed anything to the ride height since I was cleared which baffles me as to why I'm now being told it's too low?
Do you know where I can find an official Vic Roads reference as to requiring a passenger and 30kg of luggage? (Vic Roads themselves don't seem to know too much) :rolleyes:
cheers for that,
Q:
reinforce, bit of 1mm scrap with same hole drilled on tacked/ stitched welded on underneath or exhaust tube type reinforce ?
wondering if this would be a common thing cops would defect and rwc would pass in the same state....
thanks
I have had to have 2 defects cleared for to low, both times there was no request to be in the car, they just ran there roller under it and cleared the defect.
You are missing the fact that in victoria you are guilty untill you prove you are innocent, might sound a little sceptical but when you look at things like an epa notice for noise and emissions, they make you prove your innocence, if you dont prove it your automatically guilty (if you dont get it tested and cleared you get fined), the cops do what ever they like and its up to you to prove they are wrong.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
