RE: The Blue Battery Triangles.
If you forget or can't get to a race shop during business hours. Just get some blue electrical tape and make a triangle. This will also pass.
Also I believe the harness required for modified class is a WRX Club rule not a CAMS rule at this stage. But this is for your own good, as your life is worth a lot more than the harness and it's definatly a good thing to have and encourage others to have regardless of what class.
  • Replies 307
Posted Images
I will have a roll of blue tape on the day if anyone needs some
RE: Bonnet pins
cheers Al
well I WAS going to fit them on the weekend... had assumed autobahn or supercheap would have some but neither did... can anyone point me in the right direction?
Revolution Racegear, Maroondah Highway. $39 per pair.
Saw 'em when I picked up my pretty Blue triangle. :P
hey its anthony again
Does anyone know of a race place in SE suburbs
otherwise blue tape sounds good but will look crap
i have a screamer pipe lol ooops too loud maybe
i dont care IM IN
i need triagle, rope, and maybe a hose for my catch can thingy i should have got a catch can when i did the car. it will be because oil can come out and drip on the track
moddified class cause i have big turbo, inj, pump, ect ect ect 238.8rwkw out of the little rb20
dont know how long it will last though
Hey id like to meet up with all you boys when i get there im sorta a new member
i suppose i just look for the skylines??? SAU stickers?
we should all meet up some where.
Nasty Troy... what happened?
Jame's farking cat happened :whistling:
LOL...if your reading this Mr Ward your cat is going in the blender tonight :P
So need tyres (cant find RE55s) , just threw some more money at the car so it looks like the alignment and car will be ready (reinstall cooler etc). Just need to kill the cat and get tyres...may be the straw that breaks my back
GMP in Oakleigh - http://www.gmpracingproducts.com.au/home/
Meridian Motorsport in Moorabin - http://www.mmsport.com.au/
Both will have what ever you need. They also have lots of things you don't need but will want to buy anyways so beware. :P
As for a meet-up I was thinking the Bunnings in Cranbourne Sat morning some time if anyone is keen?
Yeah man im there Cruise all together ive got some mates coming in my car too.
JUST FAXED IT WHOOOOOO FIRST TRACK DAY CANT WAIT
hope my car holds up i wont drive too hard just in case
im going past the oakliegh one then tomorrow after work
hey im a bit worried about the speed limiter???
i just searched... is it only with the stock ECU ??
I have a wolf 3d ver 5 but havent tried to go over 180km on street to check if its on my car still?
will it be removed if ive done the computer?
i dont want it to kick in on track day
Because it ate all the dope i was going to sell Wed night to fund the weekend. So no dope means no money, and a high cat isnt really worth much to anyone. Thats whey im going to blend it up and try to make hash cookies out of it
If anything you both shared the dope! put it on ebay, you may be surprised.... whats with not finding any re55's? i was at donellans and they have shit loads! surely in your size.
Will try Donellans in the morning, but the two places i tried, (one place is cheaper) have been hesitant to say they can get them. Crosses fingers....then of course i need to get them over to my car and fitted and then a wheel alignment, then the seat and harness to go in...busy, busy, busy :)
i really wanted to see your car troy remember me the guy with the big turbo and no power?
well the dyno at rank rotary was a bit out RE customs on the dyno day i pulled 238.8 @ 20psi
a little better
Rank rotary did a compression test and my bottom end is worn i need REBUILD :P
rings are screwed anyway ill catch up wit ya another time if you cant make it
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
