RE: The Blue Battery Triangles.
If you forget or can't get to a race shop during business hours. Just get some blue electrical tape and make a triangle. This will also pass.
Also I believe the harness required for modified class is a WRX Club rule not a CAMS rule at this stage. But this is for your own good, as your life is worth a lot more than the harness and it's definatly a good thing to have and encourage others to have regardless of what class.
  • Replies 307
Posted Images
I will have a roll of blue tape on the day if anyone needs some
RE: Bonnet pins
cheers Al
well I WAS going to fit them on the weekend... had assumed autobahn or supercheap would have some but neither did... can anyone point me in the right direction?
Revolution Racegear, Maroondah Highway. $39 per pair.
Saw 'em when I picked up my pretty Blue triangle. :P
hey its anthony again
Does anyone know of a race place in SE suburbs
otherwise blue tape sounds good but will look crap
i have a screamer pipe lol ooops too loud maybe
i dont care IM IN
i need triagle, rope, and maybe a hose for my catch can thingy i should have got a catch can when i did the car. it will be because oil can come out and drip on the track
moddified class cause i have big turbo, inj, pump, ect ect ect 238.8rwkw out of the little rb20
dont know how long it will last though
Hey id like to meet up with all you boys when i get there im sorta a new member
i suppose i just look for the skylines??? SAU stickers?
we should all meet up some where.
Nasty Troy... what happened?
Jame's farking cat happened :whistling:
LOL...if your reading this Mr Ward your cat is going in the blender tonight :P
So need tyres (cant find RE55s) , just threw some more money at the car so it looks like the alignment and car will be ready (reinstall cooler etc). Just need to kill the cat and get tyres...may be the straw that breaks my back
GMP in Oakleigh - http://www.gmpracingproducts.com.au/home/
Meridian Motorsport in Moorabin - http://www.mmsport.com.au/
Both will have what ever you need. They also have lots of things you don't need but will want to buy anyways so beware. :P
As for a meet-up I was thinking the Bunnings in Cranbourne Sat morning some time if anyone is keen?
Yeah man im there Cruise all together ive got some mates coming in my car too.
JUST FAXED IT WHOOOOOO FIRST TRACK DAY CANT WAIT
hope my car holds up i wont drive too hard just in case
im going past the oakliegh one then tomorrow after work
hey im a bit worried about the speed limiter???
i just searched... is it only with the stock ECU ??
I have a wolf 3d ver 5 but havent tried to go over 180km on street to check if its on my car still?
will it be removed if ive done the computer?
i dont want it to kick in on track day
Because it ate all the dope i was going to sell Wed night to fund the weekend. So no dope means no money, and a high cat isnt really worth much to anyone. Thats whey im going to blend it up and try to make hash cookies out of it
If anything you both shared the dope! put it on ebay, you may be surprised.... whats with not finding any re55's? i was at donellans and they have shit loads! surely in your size.
Will try Donellans in the morning, but the two places i tried, (one place is cheaper) have been hesitant to say they can get them. Crosses fingers....then of course i need to get them over to my car and fitted and then a wheel alignment, then the seat and harness to go in...busy, busy, busy :)
i really wanted to see your car troy remember me the guy with the big turbo and no power?
well the dyno at rank rotary was a bit out RE customs on the dyno day i pulled 238.8 @ 20psi
a little better
Rank rotary did a compression test and my bottom end is worn i need REBUILD :P
rings are screwed anyway ill catch up wit ya another time if you cant make it
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
