had some of the camber taken out of the rear the other week, and have used only one tank since, so not sure if i've just been driving gentler than normal or if its cause of the wheel alignment but i just got 400 out of a full tank, previous best was bout 330 for same city driving (average 290), highway when i drove it back from brissy i was getting approx 400-450 per tank, fingers crossed my fuel bill will be a bit cheaper now
  • 11 months later...
I was getting 300-350 regardless of driving style.
Changed the o2, coolent temp, afm. I'm now getting 400+ with 50L of fuel.
Should just get a nistune sisbro, it will give you better economy than what you will ever get from brand new sensors.
I've been told you can expect 50-150k extra from a tank with a nistune. So you would make back your money within a year easy
only managed to fill the stagea up once, and it got 396 when i got to e mark, not sure if that's good or not, car is still totally stock, gonna look at removing the middle muffler if i can't get a cat back exhaust soon enough
let you know how it goes once the new clutch goes in, and then when I sort the exhaust
Series 1 RSFour, big front mount, rear muffler removed (replaced with small 2.5" dia canon, so nearly standard ex) rest of engine stock, standard 5-7psi boost and manual conversion, always does 400/tank regardless of city or hwy.
Although once got 450/tank on E100 but can't get it where I live.
Not real good on fuel but its a great car, so I don't really care!
My old hsv 185kw vs 5L was good at 8.5l/100km but was no where near as fast as the stagea, or as practical!
Old thread. New s2 rs. Lucky to get 150k out of 3/4 tank!
Cleaner afm last night, reset ecu, will change o2 sensor, wish me luck!
This is why X km per tank is a useless measurement.
Even if we consider "a tank" to be 60 litres on the conservative side, you're still using 45L per 150km.
That's 30L/100km, and totally absurd for normal road driving. Except if you owned an old turbo bentley, or a veyron....
You need to do a proper measurement first.
Driving 95 percent of time off boost I managed to get 16ltr per 100 much better than over 20ltr before
Hopefully the 02 sensor helps. I noticed the exhuast fumes smell really rich on cold start, not sure if the 02 will help or there's another adjustment somewhere?
16L/100km is still above average, but only by about 3L/100km
Has a previous owner done mods to it? Different injectors? If theyre stock, perhaps try taking them out and getting cleaned professionally, they may be working poorly.
When's the last time an alignment was done?
What length of trips are you normally driving?
With the wheels off the ground, how easily do the wheels turn? Are any brakes binding?
Anything over 20L/100km for normal driving is a worry though. The fuels gotta be going somewhere. Is the back of your bumper sooty around the exhaust?
Only had the car for about 6 weeks, the car is stock I believe
Most of my driving is very short trips but again the needle doesn't move in front of my eyes like before I cleaned the afm and tightened all the loose cooler pipes
No black marks around my bumper
But the cold start stinks my garage out bad
RS4s with 71k kms, stock aside from Nismo cat back and k&n panel. 400km's out of a full tank (55odd liters), 80% urban driving, 20% freeway. Can squeeze 450km's if I drive like there is a cop behind me everywhere I go... Otherwise not a heavy, not a light foot.
Cold start REAKS and I have black soot around my bumper so I'm guessing it's running the standard jap rich :P. So pretty happy overall.
Few mods and a nistune and I recon it'd get better
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
