just the regs, carpet is required. In fact Targa spec is 99% stock. Its funny how similar the r34 is to the r32 once you pull all the interior out, almost a carbon copy
My zed is stock too. Stock UAS zed version.
Nice Link Beer Baron and these are probably the best arms on the market.
Geometry changes
Some good info here but it is not a matter of just throwing these parts at the car and need to measure adjust and test. The bump steer fixing rod ends outer sockets need to be tested on the car as we found a few mm either way made a big difference to bump steer. They are often too low and need to be machined or spacers removed if they come with this option. Bottom line is there is a sweet spot and need to measure bump steer changes to find this spot or ideal height of these steering arms. Also changing roll centre by fitting these lower arms with roll centre adjustable rod ends over power the top arms and cause more camber and toe change even though it does raise the roll centre. It is better to raise the pivot point on the top arms on cradle which we are in process of doing. Lot easier to do a GTR than a zed as chassis rail on zed is lower and tighter clearance.
I opened up unique cars today to find a wright up on troy, some chick and rb20 powah at the dutton. had some good pics of the car. And according the article troy is a crazy driver, crazy but fast, and likes passing ferrari's round the outside :)
or like this even better:
i have ordered one of these Maple A-1 Gages, should arrive in a few weeks. will keep everyone updated once i get some camber & castor bushes in.
anyone know the equations required to calculate castor?
I chopped everyone at the state champs, even the evos. The other 31 cars arrived later once they stopped 2wd wheel spinning
but then one of the sneaky buggers got past and I was running 2nd for 7 laps.
then the motor blew up. pretty much the normal day for a GTR
I don't know it off the top of my head. but basically you need to mark out on the ground 20 degrees of steering angle both ways. turn the wheel 20* left, measure camber. turn is 20 right, measure camber. do some maths. bingo castor. lol.
but it's not so crucial just for stuffing around the know the exact degree of castor. you can adjust just by measuring the rod length. shorten the rod for more castor, lengthen for less. just keep both sides the same and adjust it till you are happy with how it feels.
you will probably find the only things you bother adjusting at the track are toe. maybe camber if you are hardcore!
you make it sound so easy eh Rich :D
i'm running a compromise alignment for street & track now, and now that i've got a set of track rims which i intend to throw some semi slicks on, i hope to be able to run more camber and fiddle with toe settings.
are castor and front camber adjustments independent of each other? (i.e. will adjusting one affect the other?)
this will be all a steep learning process, will just fiddle with sydneykid's recommended settings until i find one suitable.
I found this equation:
Caster (deg) = (180 / 3.1415) * [(camber1 - camber2) / (turnangle1 - turnangle2)]
but it was for a mazda miata (mx5?) - i never did physics (study biotechnology :domokun:) but the equation seems fairly measurement based. the only number i'm not sure about is the 3.1415, which from memory looks like the value for pi (however i always used 3.142 at school).
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
    • Yeah Jap import. Fairlady Z then! I'm a bit the same.  They've been on my radar for a fair while but then just impulsively decided to buy one!  Was going to just buy an NA and add turbos to it later but decided to save the f'ing around and just buy the turbo version.
