just the regs, carpet is required. In fact Targa spec is 99% stock. Its funny how similar the r34 is to the r32 once you pull all the interior out, almost a carbon copy
My zed is stock too. Stock UAS zed version.
Nice Link Beer Baron and these are probably the best arms on the market.
Geometry changes
Some good info here but it is not a matter of just throwing these parts at the car and need to measure adjust and test. The bump steer fixing rod ends outer sockets need to be tested on the car as we found a few mm either way made a big difference to bump steer. They are often too low and need to be machined or spacers removed if they come with this option. Bottom line is there is a sweet spot and need to measure bump steer changes to find this spot or ideal height of these steering arms. Also changing roll centre by fitting these lower arms with roll centre adjustable rod ends over power the top arms and cause more camber and toe change even though it does raise the roll centre. It is better to raise the pivot point on the top arms on cradle which we are in process of doing. Lot easier to do a GTR than a zed as chassis rail on zed is lower and tighter clearance.
I opened up unique cars today to find a wright up on troy, some chick and rb20 powah at the dutton. had some good pics of the car. And according the article troy is a crazy driver, crazy but fast, and likes passing ferrari's round the outside :)
or like this even better:
i have ordered one of these Maple A-1 Gages, should arrive in a few weeks. will keep everyone updated once i get some camber & castor bushes in.
anyone know the equations required to calculate castor?
I chopped everyone at the state champs, even the evos. The other 31 cars arrived later once they stopped 2wd wheel spinning
but then one of the sneaky buggers got past and I was running 2nd for 7 laps.
then the motor blew up. pretty much the normal day for a GTR
I don't know it off the top of my head. but basically you need to mark out on the ground 20 degrees of steering angle both ways. turn the wheel 20* left, measure camber. turn is 20 right, measure camber. do some maths. bingo castor. lol.
but it's not so crucial just for stuffing around the know the exact degree of castor. you can adjust just by measuring the rod length. shorten the rod for more castor, lengthen for less. just keep both sides the same and adjust it till you are happy with how it feels.
you will probably find the only things you bother adjusting at the track are toe. maybe camber if you are hardcore!
you make it sound so easy eh Rich :D
i'm running a compromise alignment for street & track now, and now that i've got a set of track rims which i intend to throw some semi slicks on, i hope to be able to run more camber and fiddle with toe settings.
are castor and front camber adjustments independent of each other? (i.e. will adjusting one affect the other?)
this will be all a steep learning process, will just fiddle with sydneykid's recommended settings until i find one suitable.
I found this equation:
Caster (deg) = (180 / 3.1415) * [(camber1 - camber2) / (turnangle1 - turnangle2)]
but it was for a mazda miata (mx5?) - i never did physics (study biotechnology :domokun:) but the equation seems fairly measurement based. the only number i'm not sure about is the 3.1415, which from memory looks like the value for pi (however i always used 3.142 at school).
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
