glad to hear about the english conversion!!!
any idea on a price?
I am still trying to finalise the price at the moment. The exchange rate is not helping but I should but be able to firm up the price in the next week or so.
Cheers
Andy
Is that it!?! fark it is small!
Thanks for that Jules, answered a few more questions for me. :(
It may be small but that Bose set up is all that you need and the bass rocks the whole car....No need to go aftermarket unless you really love your Bass Bins.....LOL
Don't know wether this is the number or not...but it's the # on my receipt from Nissan. Pretty sure they are NGK as well.
NI22401-5M016.....they are also $24.15 each.....add's up when you have 6 of them :action-smiley-069:
Hey guys, Denso have Irigium spark plugs for VQ25det.
I have been speaking to a guy there about ordering some in through Denso themselves - which they "don't normally do".
I have been quoted $13.50 + GST per plug, $16.50 shipping for a total of $97.50.
They also have a lifespan of 150,000km's.
Part #IKH22
The only downsides are money up front & there is a 3 month wait for their next order.
If anyone is interested in getting a set, send me a PM.
As an aside the EVO9 shares the same plug and Denso supply OE to Mitsubishi, so there might actually be some in the country.
ohh and it might be possible to get them from mitsubishi even cheaper as they would probably buy in bulk lots. ohh and own a percentage of denso :P
You would think so wouldn't you?
Instead of being able to find anything in the book for Denso plugs (I was calling up about plugs for an EVO9 as they use the same plugs as my m35), I was offered a set of NGK 1GR78-G plugs... Platinum... at $53.40 EACH!!!!!
This from an authorised RalliArt dealer!
It would also seem that Nissan Japan are out of the Plugs that Tony specified and do not have a restocking ETA.
Looks like I have a 3 month wait ahead of me, DAMNIT!
Can anyone tell me what the problems with the plugs that I got from Nissan are?
NI22401-5M016.....they are also $24.15 each. What's the difference between these and the one Tony is suggesting?
Dunno bud, probobly nothing more than heat tollerance. I may just be paranoid :) ... I presume that you have had no issues with your car (?)
All I know is that;
1. Different Nissan dealers give me part numbers for different plugs.
2. The guy who has been complying the M35's for the longest period of time wanted me against using any other Nissan/NGK spark plug to the one I specified earlier.
3. The Denso Iridium plugs have a 150,000km lifespan, supposedly outperform any platinum on the market and cost around $16 each including GST & delivery.
4. NGK are probably the least helpful group of people I have ever tried to deal with.
*sigh* since I don't really need them now, and after reading all that I have, I will probably get the Denso plugs and wait the 3 months.
  • 4 weeks later...
OK finished updating the above info... is there anything anyone wants more info on? anything need correcting? any other RAWS people know of to add? other parts links? etc etc?
I'd just like to add another workshop offering compliance for the M35's.
Carmen Imports in Brisbane (www.carmenimports.com).
Anyone after more info on these guys, PM me in 2 weeks time ;)
ok thats another stagea that I have to do there... (I do carmens electrical compliance work :bunny: )
top fellow. check out the two legnums whilst you are there. I've had my hands in both of those and they have naviagtion on them
ok thats another stagea that I have to do there... (I do carmens electrical compliance work ;) )
Hey i went there today to check out my new stagea. Didn't read your post until just now but I did see a couple of legnums there, and a galant. Leggy's aren't really my cup of tea, but they are a nice car :banana:
I'm hoping to be able to drive my car home in 2 weeks time so hopefully things will go to plan...
Mine has no screen or tv/nav stuff so your job should be pretty easy on it i'd imagine. Is it just the radio that needs attention? ie. band expander install to pick up aussie FM channels...
PM me once you've worked on it if you like :banana:
Its been a long wait but from what I saw this morning, worth every second :D
will do. I'm dropping a car back there in the morn so I'll look at it then. PM me the Chassis # of it pls.
the radio can be done at teh same time.
do you have a dash shot of this car?
    • Biggest thing is you're okay!   It sounds like between the accident, and the drive home, it was a pretty torturous trip again! On the bright side, you took the opportunity to enjoy the event more from the perspective of a spectator, than as an entrant!   Sad to see so much damage to the car. It really has taken a HUGE hit in the front end. If/when you choose to repair, hopefully the rails are straight (At least from shock tower backwards). Hopefully the extra cage coming through there has save most of the chassis rails, and HOPEFULLY saved the motor too. Best of luck when you eventually get motivated to start pulling it down to check it all out
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
