I would definently say you need carbs.
Your brain needs glucose.
If you are trying to build muscle/put on size I would think you'd need a reasonably large amount of complex carbs along with lots of protein.
I don't like following diets and it's pretty surprising how much healthy food you can eat without getting fat when you lift 4+ times a week.
Your body doesn't need carbohydrates to function, but it does need them to function efficiently.
If you have to abstain from carbohydrates in your diet, then you are eating the wrong carbs.
Dare i say it again, but if you eat properly, you will never have to go on a diet.
This... f**k low carb diets
For those that have asked about Albuterex previously:
http://www.tga.gov.au/safety/alerts-medicine-albuterex-xtreme-121221.htm
Looks like it might have been a lot more effectively than previously speculated LOL
no it's not a measurable difference, you can burn up to an extra 60 calories I believe
Actually you are mistaken. There is actually no such thing as negative calorie foods, despite what the health gurus like to say. Generally speaking, about 5 to 15% of our daily caloric intake is wasted on digestion. The highest burning substance is protein at about 20 to 25%. That means that if you eat 100 calories worth of protein, it will take 20 to 25 calories to digest it.
Celery on the other hand has very little nutritional value, and contains cellulose (which the body can't digest), so it takes very little energy to digest (and chewing it takes bugger all energy either, something like 10 to 15 calories per hour). So if you eat a stalk of celery (containing about 8 calories), you will only burn off 1 or 2 of those calories in the process,
http://www.tga.gov.a...reme-121221.htm
Chestbrah won't be happy.
Dam and I was going to give alburtrex a go........
In the states at the moment, haven't hit the gym for 2-3 weeks. Feeling the effects already some good and others not so much. Shit food is doing my head in as well. The yanks need some lessons on how to cook eggs and bacon
yeah I want to get to the gym as well. Far too much good food and wine with little exercise.
But..... bloody well shagged my left knee joint after it collapsed on me, twice. Hopefully just a cruciate strain or small tear, but cant tell at the moment.
Might head in anyway and try some upperbody stuff. Just dont want to stand up much atm.
    • Even with no BOV you will have issues unless the MAF is a hot film type like the R35 which has some design features to deal with reversion. Hot wire MAFs are very sensitive.
    • So i just change the (whatever is inside ma original MAF and slide the R34 MAF (it is gonna fit right in? ) and somewhere on the hot side a BoV...i presume that would be vented to the atmo? I just "trying" to understand...maybe my mechanic would know this   I would not mind(even prefer) to run stock BoV cuz it is way more than fine but i do not have that and only pipeing what is left is oem J pipe ... I will be running Blitz fmic(to fit oem one side style) and i gonna need custom pipes cuz i do not have rest of those pipes and hoses... But i am want standalone ECU. Only choice i have atm is Nistune...but that is not gonna cut it right?I dont know what Nistune can and cant do... I know you guys know Link and Haltech...but whatabout ECUmaster? I know guys in here run those but i literally do not know about that and do not know differences... Just know to take whatever "my" tuner can work on.
    • Is that the blue one rpm?
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
