Did my 1RMs tonight - 230kg squat, 200kg deadlift, 120kg bench, 70kg press. Stoked about it - I hit all the goals I was after, and squatted more than I thought I could. 8 or so months of PTC beginner routine and eating LOTS of protein.
Now for my 5/3/1 to begin!
Paradoxically the only thing to cure my calf doms was squatting.
Edited by bozodos
I always go below paralell Birds, I try not to have hamstring touch calf though. Still at 120kg or so unfortunately - diet started to get a bit out of hand again lately. Would have liked to got 240kg squat for double bodyweight, but I didn't want to fail it.
Can't really remember my starting numbers, they were pretty damn low though - when I started the PTC routine I was benching around 40kg, squatting 100 or so, and deadlifting 80. I had to do dips with ~90kg assistance, which I can now do bodyweight.
I've started doing stair / hill runs and sprints to get some conditioning in too.
Sensational man, really happy for you, so jealous of the Squat and DL =D
Happy because you've worked hard for it and happy because your attitude has been excellent since the beginning, no bullshit, no ego, just getting in there and getting it done.
*BroHug*
  • Like 1
Good work Boz. Only real powerlifters squat more than they deadlift!
Don't need to worry about knee wraps but a belt for squats is really handy, especially once it gets heavy. Just helps you keep tight and makes the whole thing a nicer movement.
It doesn't really protect your back and only maybe gets you a handful of kilos but it's definitely worth having.
Thanks Nick. I'll look into a belt - my Chuck Taylors are here so at least I'll have some reasonable footwear. I've had a strong squat and legs since I started, lucky I guess.
Been agonising over 5/3/1 assistance templates, I decided on Simplest Strength due to it having a squat and deadlift variant more than once a week, and not eating enough to give BBB a hard go
5 sets of 5, there's a heap of different programs, Markos always used to reccomend it more for lifters beyond the beginner stage, and I'd agree with that.
Common examples of programs are: Stronglifts, LP Greyskull, Madcow, Bill Starr's 5x5.
Cheers boz, I had a quick look online but thought id ask my fellow gym sauers. I had a chat with a 50 year old at the gym today. This bloke is bigger than most blokes at the gym. He said for me to shake up the routine ( 5x5, pyramid etc ) he swears by the pyramid program.
http://blackironbeast.com has a good calculator for 5/3/1.
I have started the boring but big program 4 day, very similar to the program I was doing but all the % and sets are done for you.
I will roll with this for the full cycle (about 9 months worth) from now and see how it goes, 2 days in so far.
I like it as it seems its a "get strong for dummies" type of thing, which suits me down to a tee.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
