  • Replies 312
Posted Images
the supras are an awesome car. plenty of grunt and huge potential. i was looking to buy one before the skyline. i only chose the 33 over the supra due to the supra being a bit too bulky for me. oh.. and i didnt like the interior. too spaceship like.
Tell your friend to get a targa top Supra, hes gonna have trouble fitting his head in it otherwise...
Supras aren't a bad thing IMO. NA ones are ghey, but TT manual ones = :)
I think they are too heavy, the styling looks good from some angles but completely obese from others and the interior is questionable - but at the end of the day, that engine...
2jz ftmfw
Yeah and he smashed it hahahaha
do turbo model supra's only come in TT?
im sure Nick(hulk's son) changed to a single turbo..confirmation....?
yeh i watch the show a fair bit.
Last night Hulk learned how to drift aswell to show Nick and Hulk ripped some nice circle work in a Practice 350z. not bad,not bad at all.. and yeh Nick was driving a Dodge Viper(drift car) i think,was all colourfull,
im only used to seeing Vipers in blue.
Nah its a HUGE trend with supras to flick the stock twin setup and put a T51R or T04Z on there
as much as it pains me to say this but a 2JZ (with turbo and plenum swapped positions) in a GTR would probaby the ultimate thing.
:) You're right, but something inside just tells me "but there's more to it than that..."
It's be unfair if the RB was stronger than 2JZ...the only fans Toyota would have would be mums dropping the kids off every morning ;)
Supra = cheap drag car
GTR = out-of-the-box circuit monster
was going to buy one till i sat in it... how small is the interior!! how crappy does it look... the back seat is pointless.. and most come in auto!!
exactly what I wanted to say...!!! I used to love supras until the day came when I actually sat in one.Me being 6ft tall i had the drivers seat pressed against the joke of a backseat.And even then I just couldnt believe how such a big car can be so small inside..Honda Integras have more interior room FFS.
Those who complain about the weight of the supra are totally misinformed, the supra weighs 1510kg go and check the weight of an r33 or 34 gtr and you will get a surprise.
The 2JZ shits all over the RB26 for strength, durability and potential. The six throttlebody manifold on the RB26 is a beautiful thing but is a negligable advantage in the overall scheme of things. Lets face it, that extra .4 of a litre more than makes up for those throttle bodies.
The 6 speed Getrag is near invinceable, there are supras popping the front wheels off the ground run after run will over 1000rwhp and still standing upto the power, torque and abuse on an unopened gearbox. It is possible to break one but very rare all the same unlike anything nissan.
Yes the stock turbos are a pain in the ass but there are many options if you are a switched on supra owner. There are many supras running high flowed steel wheeled twins making 320+rwkw. My cousins does 327rwkw on US spec factory turbos, there is now also a manufacturer who replaces the standard cartridge with a GT28R cartridge not to mention the number of single turbo kits available.
Traction issues, what traction issues??? You can fit 325's on the rear just by rolloing the lip and getting the right offset.
By the way, its just not a fair comparison. The supra so far above the gtst(which was the original caomparison remember?) its not fair to compare.
Supra Vs Gtr, well they are chalk and cheese and both have their strong and weak points.
I am not biased, i am experienced and have owned the cars in question plus many others and if i wanted many miles of trouble free enjoyable driving(sometimes a little spirited) then i would pick the supra. Skylines, including gtr's(the r34 less so) are just too expensive to make strong, reliable and powerful.
Edited by fieds83
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
