  • Replies 286
yeah i reckon an exhaust is definitely on the agenda
want to do a few small things first
fix the seat, gear boot, gear nob, tint etc
then a few mods
im still not 100% sure if i just keep it stock or not
maybe just get an exhaust and keep the stock one in the garage, so i can always put stock back on for a fully stock re-sale
i reckon you would fetch more for a stock 32 in a few years than a molested one :laugh:
Yeh i think it was a reasonable result and he was pleased to see that it was all in order - was fresh off the boast only a couple of months back. exhaust is probably on the cards sooner or later especially after he noticed my gtst pulls away from him... :D yet his 'R' pulls hard for 100% stocko :)
old rusted exhaust = good excuse for upgrade :yes:
LOL! Yeah get the few interior things done and like what I did, you can keep the stock catback exhaust (Suprisingly the pipe is quite big) just aftermarket dump pipes and cat and keep eveything like you said.
HAHA! Getting beaten by ya bro in his GTS-T! Oh well... Looks like you do need the exhaust and maybe upgrade to a K&N high flow panel filter in ya air box.
No one has said it yet but nice work on the tea towels pete - they look tops. :D
Oh - and for who ever asked I didn't put my car on the dyno. But I had just picked it up from Racepace where it had made around 380 or something which I guess would equate to around 204 on Rays dyno. :)
thanks for the comments about the car guys :)
Big thanks to the exec SAU crew for putting on a great day!! Didn't get to try the lamb sausages though... :D
Nice to say hi to a few people, Ash, Brad, Paul, Mav, Roy, Jack, Pete, Matt and meet some new ones Dave, and the two dudes, one with that drift spec silver 32 (i'm not sure if we got each others names, sorry if i've forgotten!!)
Car didn't make what i thought it was capable of, and especially after seeing some of the dyno results here, something definitely seems a bit odd.
Here's my graph....
The curve looks ok and but seems to be well down on power considering i have a full 3" stainless system (BATMBL split front/dump pipe, 3" cat, 3" cat back HKS super dragger) And one of those $30 boost controllers.
I did notice that it was spewing out a lot of smoke though which i guess coincides with how rich the car gets. Oh thanks for Roy and Matt to explaining the AFR curve for me :(
So yeah, thoughts on the graph? I'm thinking it should be make about 20kw's more going on something like Chris's graph and even the silvia graph above.
Is there anything i can look at before i go playing with the ECU?? I'm going to get a Dr Drift remap, but if there is something i can do about it before that, i'm willing to give it a try.
where do i find the intake temp? :D
Probably a stupid question, but my tyres are 40psi or more, it says 35... that wouldn't make any difference would it?
EDIT: think i found it, IT: 22??
yeah, a few key cars had REALLY high intake temperature reading, which pumped up power considerably.
most cars had the intake air temp probe in the right place, the Airbox or near the air filter, others, well, didn't.....
Damn those lamb sausages were good even if i say so myself hehe :D
+1 on the sausages they were great. :)
I was one of the new faces and i really enjoyed the atmospheare.
My car didn't make it into any pics but. :( It was the burgundy 33 in the driveway across from r&e.
Awesome day - really enjoyed myself. BBQ wasn't bad either :D
Here's my dyno graph:
Only mods:
- GKTech split dump+front 3"
- super high-flow cat :)
- 3.5" cat-back
- Apexi Pod
- Front-Mount
- Bosch 040 Pump on standard boost. Pretty happy with that.
Cheers,
Steve.
a few key cars??
sooo.... how much of a difference does it actually make??
Daniel - your result sounds about right. give/take 10rwkw for dyno differences and so on, and its perfectly normal.
You really need to change ECU and put a good tune through it. That would give you anothyer 15-20rwkw.
Only some cars had massive IT temps, most were correct :laugh:
55deg intake temp is worth ~30-40rwkw from what i have seen when your up around 300rwkw that is.
Basically more power you make, bigger the difference due to the correction factor for intake temps.
On a 200rwkw car, the difference is around 15-20rwkw.
nothing wrong with that, curve looks good... its just a tad rich as you haven't got anything to lean out the mixtures... stock ecu sees more airflow than standard and dumps extra fuel in to be safe... hence the smoke outta the exhaust:)
thanks for the comments about the car guys :laugh:
Big thanks to the exec SAU crew for putting on a great day!! Didn't get to try the lamb sausages though... :laugh:
Here's my graph....
I did notice that it was spewing out a lot of smoke though which i guess coincides with how rich the car gets. Oh thanks for Roy and Matt to explaining the AFR curve for me :wave:
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
