Hi, does anyone knows how much oil need for engine gear box and diff in R33 Rb25det? and what fluid is better for gear box?
thanks in advanced
can i use nissan Genuine DIFF OIL HYPOID SUPER GL-5 or DIFF OIL HYPOID LSD GL-5 in gear box or those fluids are for just differential???
thanks in advanced
Edited by guricha
Good lubricant is lifestyle lubricant, comes free in boxes of 12; if its good enough for little johnny, its good enough for the box.
lolz na, ill vouch for the castrol tranzmax z though, i use it in my r34 gtr transfer case and it fantastic. For my gearbox i use v160
'lil johnny' must be doing something wrong if he needs 'lifestyle lubricants' ;)
  • 3 weeks later...
sydneykid:
If i were to buy 3 x 4L Redline Lightweight shock proof oil, could i do an R33 GTR gearbox, transfer case, and both diffs?
Is this oil suitable for all 4??I
want nothing but the best for my beast :)
Cheers.
  • 1 month later...
For a sticky.............................
What we use;
4WD Transfer = Castrol Transmax Z
Automatic Transmission = Castrol Transmax Z
Manual Transmission = Castrol Syntrans 75W-85 or Castrol Syntrax 75W-90
Differential = Castrol SAF-XA
Cheers
Gary
Hi SK
I've had a 33 for a couple years now and everything i've had to do to my car, i've been able to figure out from your posts. I'm sure you hear it a lot but just wanted to say thanks for the knowledge - you make dumb a$$e$ like me be able to work on their cars.
cheers mate
Hurf
  • 3 weeks later...
I just put the Redline Lightweight Shockproof Gear Oil in my R34 GTT. I only needed the one bottle, is this right?
Also is this oil a good oil to be using in the gearbox?? And is there any different weights available for this oil or just the one?
I've been having a grinding noise when dropping down gears at higher revs eg. 60km/h into 2nd makes a grind, 110 into 4th grinds, 3rd grinds when I shift up from 2nd at higher revs...
I changed gear box oil to see if the problem would go away but it hasn't :S I think it may be clutch related though as the grind can be felt through the clutch pedal when releasing it and the gear engages.
Could it be the clutch or thrust bearing??
Any help would be awesome!!
i believe nissan say 7.5w/30 - where the f*ck you get 7.5 i have no idea...
Marcus, do you know about www.performancelub.com? if not, all the oils you'll ever need are there.
If the 26 sees mild track use, i'd go with a 10w40 (Royal Purple, Amsoil, Redline, German Castrol)
Street use i'd be more inclined to use an 0w or 5w. 5w30 is probably you're closest to the factory specs.
I'm running 5w30 Royal Purple at the moment.
  • 3 weeks later...
would castrol saf-xa be fine for r32 gtst diff??
thanx heaps been trying to find this sort of info
  • 1 month later...
  • 3 weeks later...
In my R32 GTR, I've decided to run:
Gearbox: Redline Shockproof Lightweight
Front Diff: Redline Shockproof Lightweight
Transfer Case: Redline High Temp ATF
Rear Diff (LSD): Redline Gear Oil 75w90
gotta love www.performancelub.com
On a 4WD; I assume that there is a filler plug if I don't want to fill my transfer case from the shifter hole? Looking at the workshop manual it seems to be at the rear of the transfer case on the driver's side of the rear propeller shaft - is that right? Also, the service manual suggests that a sealant (Three Bond 1215 - genuine Nissan part KP610-00200) should be used when installing the drain plug - is this unnecessary? If it is necessary shoudl the same sealant be used when installing the drain plug into the gearbox as well? Thanks, Ben.
My mechanic (GTR specialist) is quite happy to do (bit reluctant) the gearbox and both diff fluids I've mentioned, but insists will only put in the genuine Nissan Matic-D ATF in the transfer case (I won't argue with him, he worked at a Nissan dealer for 7 years so I will go with what he says). Did alittle research into it and it seems most jap tuners say to only use the genuine Nissan Matic-D in the transfer cases. Then again it's suggested Matic-D is nothing more than Castrol ATF/Mercon IV.
I think this is a interesting read (copy and paste from elsewhere, Matic-D and the special powersteering fluid mentioned are the same part-number)
Have a document from Nissan NZ, which came from Mr.K.Shindo of Nissan Japan.
It outlines his thoughts on fluids that should not be replaced by aftermarket products.
1. Transfer case fluid
Nissan Matic D is strongly requested because high torque is applied to transfer unit.
2.. Transfer case (ATTESA E-TS-PRO Actuator) : It is not acceptable to use DEXRON III fluid.
> Only Nissan Power Steering Fluid Special use is required.
Today I received the technical information from our design department.
1. The difference between the DEXRON III and Nissan Power Steering Fluid Special
The viscosity characteristic of Power Steering Fluid Special is lower than that of ATF DEXRON III and the resistance to wear is also improved. Each viscosity is the same level at 100 deg.C and the former viscosity is designed to have the lower value for under 100 deg.C than the latter viscosity.
This characteristic is aimed to rotate an oil pump located in ATTESA PRO
actuator easily at the extremely low temperature (Around -30 deg.C or -40 deg.C)
2. What will happen if a customer puts DEXRON II or DEXRON III into the ATTESA PRO actuator reservoir in the trunk ?
The 4WD performance will be largely decreased at the low temperature because the viscosity value of DEXRON II or III is extremely high compared to that of Power Steering Fluid Special ;
As the rising characteristic of 4WD torque transfer becomes worse, it takes the longer time to transfer the driving torque to the front wheels. There is a possibility that the 4WD cannot be achieved in the worst case.
When I asked for fluid for my transfer case at Nissan in Rockdale (who proport to sell to imports and provide Nismo gear) I was told that any automatic transmission fluid would do. I asked abour gearbox oil, thy told me that they ony sell in quantities of 20 litres and did not have the specified viscosity.
Castrol recomend Castrol Transmax Z, so do Sydneykid and Duncan; just my two bob, but that'll do me!
Moodles 2; can your mechanic get 2 to 4 littres of Nissan Matic-D ATF or is he getting it in large quantites being a mechanic and all?
My mechanic gets really good prices from the Nissan dealership he used to work at, I'm not sure how how many litres he got all I know he priced it for me as $50, all I know it's enough to cover the ATTESSA (0.5l if duncan is right) and transfer case (1.5l), so I guess 2-3litres.
edit: plus he owns a R32 GTR as well so probably brought for his supply as well.
Your comment about needing 1.5 litres got me to thinking as Duncan has suggested that the transfer case takes 2.0 litres. I looked in the workshop manual and it suggests 1.8 litres. For the record I put 2.0 litres in mine last night (I could not get the filler plug out and thought it would be just as good to pour in the exact quantity). I didn't notice any real problems today; but I guess the difference between 1.8 litres and 2.0 litres is relatively small!
For fluids the manual recommends
Transfer case (page CH-59) - 1.8 litres of Nissanmatic fluid D [approx. 1.8 litres]
Manual transmission (page CH-23) - Nissan gear oil MP-G special GL-4 #75-90 [approx 4.1 lites]
Front final drive (page CH-125) - Nissan gear oil hypoid GL-5 85W-90 [approx. 1.0 litre]
Rear final drive (page CH-125) - Nissan gear oil hypoid LSD GL-5 80W-90 [approx. 1.5 litres]
I have no personal opion as to the products and quantities; but I thought I would provide reference to the manual to round out the discussion.
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
    • I assume clearances were all a-okay?
    • Shock tower brace is in +5Kw....LOL
