white 32 4 door on calder heading towards sunbury and then turned around to catch me i went down calder park drive but he didnt follow
thena gun metal grey 32 4 door at the lights turning into watergardens
and thena maroon 32 4 door at epping autobarn, this thing was nice, looked like origin kit and work crKai rims :)
think its 4 door day today :P
Spotted my self in a silver R32 today, was at the BP on Princess Hwy about 435pm and saw the reflection of the car as I drove past the windows of the shop front
Was looking for Paul, anyone know were he is?
He's not at BP Hallam thats for sure
Spotted a silver R32 kind of like the one described on Abu's post, it was sitting out the front of Horsepower Factory.. at around 4.55pm this afternoon, i dunno wat he was doing, he just sat there. I'll keep an eye out again though... im sus about this guy, seems DVS
did you wave or nod your head, and if so did the other driver return the gesture?
we both just looked, blank expressions with no emotion or sign of acknowledgment
driver resembled my appearance but was hard to tell as I had a few too many beers before jumping in behind the wheel
My speech slightly slurred and my eye sight blurred, I left BP in search of Paul
was the beer halal?
On Friday night at approx 2.30am at Mothers Milk near Chapel Street and Dandenong Road spotted a bayside blue R34 GTR V-Spec. On Saturday afternoon spotted a white R34 GTR with Nismo kit and rims on Chapel Street near Windsor station. I think is the same car that was for with plate "GTRJIE" or something similar. Different plates makes me think the car has a possible new owner.
Saw five modified R34 GTRs last weekend... at racepace :banana:
There was a really nice white R34 GTR with a carbon hood with a huge air vent in it - I mean if a flock of birds landed on the car they would seriously be vacuumed into it. Also saw Snowman's nice blue one - I love the Z-tune hood.
Also saw some guy rock up in an Evo 8?!? Huh? Why would you come to a GTR tuning specialist? :)
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
    • Ha ha ha, so they stopped the bearings spinning on the one you want, but then decided the crank hub should slip instead 😛   Stick to RB, at least you can work on it yourself. And now it doesn't smell of vapour   Also I still believe there's a chance your new flap doesn't "pop", as even though the engine might breath hard, it has a direct path with no restriction to the inlet, which when on boost should pull a bit of suction for you. If you do get pressure in the catch can id be very intrigued. Time to put a boost gauge on it, and a session at the track, then solid cover your vent and do another session
