I was just told there is a massive defect station on Maroondah Hwy outside the cop shop.. not sure what suburb that would be??.. but maybe avoid driving down there at all..
That would probably be the Blackburn/Mitcham area, cant think of anywhere else where the cop shop is on that road
spotted Chris in the gtr and Min in the Stag going down sydney rd just before craigieburn
thumbsup all round :whistling:
then a silver 33 gtr from tassie turned out of donnybrock rd and was going down hume highway
some fine cars on teh way to dutton :whistling:
Blue R33 GTS with Nismo wheels on middlebourgh Rd Doncaster
Blue R34 GT-R, looked stock, turning into blackburn Rd Blackburn
White R32 GT-R in the Dandy hills on Saturday, He gave me the thumbs up so I waved back.
All spotted on Fri
Spotted a Blue? R32 - plates UAD-XXX - around 3:15am turning off Tullamarine Freeway onto Bell Street.
Also spotted a Gunmetal R33 - plates UUQ-XXX - around 4:00pm passing my work on Apollo Drive.
parked opposite of rekin (uie710) today. always see ur car at eng carparks.
wat u studying dude?
haha yeah i saw your car there.
Studying Industrial Engineering & Engineering management (IEEM) 3rd year atm.
Course has been cancelled at uni, im the last group doing it :wub:
How bout your self? Get some sau-vic stickers :down:
It wasn't a defect station and it wasn't outside a cop shop. It was a drug bus in Ringwood, I got waved through.
The blitz was happening near Maroondah Highway and Rooks roads (Mitcham). Apparently cops and vicroads were pulling over a shitload of people like no tomorrow.
I hope no-one got dicked....
Really? I went through there and there was nothing.
Edited by llama_au
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
