6pm in Hallam, spotted a blue R34.. just looked fkn hot!
Looked to be a GTR but I was too far away to tell, can probably say it was a GTR as it was in the GTR blue colour with white TE37 wheels.. just looked insane and sounded tufff too
spotted my car collecting dust
LOL!
I just realised I spotted your car at 2007 Auto Salon after running through all my old pics. This was before I signed up to SAU.
Actualy there were quite a few of SAU member cars there.
Was alongside a teal N14 pulsar. Was fluttering and had a red front bar. Had sau-vic stickers too.
Spotted on ferntree gully road at 12:00pm.
Was trying to get his attention but he was looking the other way :blink:
people tend to look away from emo cars :)
DAYEM - Nice Silver 33... yes... i said a 33 was nice... only cause it had the only kit that actually makes a 33 look good and some nice wheels. SAUVIC sticker.
Was around 930 down james cook drive... followed them until they turned onto the M1
