Yesterday day I spotted GTT4DR going down Canterbury Rd then 1 min later a white R33 same road then 2 min later on Colchester rd another white R33. :P Hatrick!
And this morning a silver R33 (was it you Birds? Looked like your car :ermm:) at the intersection of Canterbury Rd and Mitcham Rd. I was in the R32.
Hahaha sorry mate, like Juliette I'm in zombie mode on the way to work. I only notice Skylines on the way home. That would have been me though.
spotted jpcr33 at crown last night and also a black r35 gtr there
james you need to call gamblers help....1800 858 858...i got the number there for you so you might decide to call...all the free time is killing your brain....LOL
hey poker is fun alright...$550 profit last nite....around $2k profit last 3 weeks :P
Was the gtr near the elevators?
it was in the basement car park and it was still there around 4am when i left
Saw 2 Skylines on the way home from Uni today.
Silver R34 coupe at the traffic lights of Mc Kechnie St/Main Road St Albans. stock GTT mags, Stock coupe spoiler, lowered, and some funky side skirts.
Silver R34 at the roundabout on Sunshine Avenue & the road that goes to Taylors Lakes.
could be me ...
Spotted a grey 32 on pound road this mornign around 8 45...then a black 33 on monash fwy (had no wing) heading towards cranbourne....then spotted Andrew on the fwy too just before the heatherton road exit heading the same direction...
Spotted this morning a R33 with SAU sticker on it. It was Princes HWY near chaddy... Had some decals or something on it, like some sort of purple waves and white stars all over the side... (to quick to see any other details as i was heading the other way)
And i spotted a red R34 with black spoiler turning on to lorne st off queens rd...
Saw what looked like krzysiu's car on Springvale Rd just outside of Glenny at about 3:55 pm. Was orange with a black lip spoiler but not positive.
Then driving past Ann St in Dandenong on the way home at about 4:10 pm and saw a black 33 with SAU stickers parked. Looked like Basti's, but again not sure.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
