Saw a yellow R34 coupe that had a black bonnet with number plates "GFORCE" on the way to monash uni in the city today at around 8am (on elizabeth street melbourne central), i've seen it twice so far during this week, wonder if the owner uses it to go to work or something?
Cheers man, more than happy to have a chat next time if you see me again :)
For sure. Hopefully I'll be in my 'line then :)
Yarp that was me heading to work -_-
Haha thinking back on it, it was probably monday. But eh. I was heading to uni -__-.
Yellow r34 pulled up beside me on Princes Hwy (Springvale area) Thursday around 2pm ish. Think you beeped to say hi, may have ignored you, lol; didn't realise you were a sky until you drove infront (if you're on here, sorry didn't mean to be a snob) ;p
  • 2 black 4-door r34 on my way to chaddy this arvo, about 1
  • black s15 on chaddy, parked beside me
  • on the way home from chaddy: red 300zx, silver 370z, yellow s15, red s15
  • 1 white 4-door r34 coming home from chaddy on footscray rd about 2:45pm
white r33 gtr with black te's and jap leaf symbol on the side qrter windows. Parked on Boronia/dorset rd intersction. Blacked out indicators too i think
twas me, no plates anymore :nyaanyaa:
and haha Rotas fooled ya :P
haha was thinkin it was you but why the plate change? Also no sauvic stickers?! Whats going on man haha
haha I decided to sell the plates, thinking of something else to get :)
and yeah never got sent any new SAU stickers with renewal :( havn't had them since my old non turbo!
Spotted an M35 (I think) Stagea at Bunnings Narre around 1:00 today, in black with SAU stickers. Looks bloody hot, no Stagea badging on it though. Was in my brothers car so you wouldn't have noticed me.
Also the same white V35 coupe parked in Berwick where the IGA is around 8:00 tonight, see you regularly near my shop there, would like to know who owns it, it's a great looking example.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
