Yer buddy it was me again, I was trying to get in the left lane for the Millers rd exit when I spotted you, thanks for letting me in I thought I was going to miss it. :thumbsup:
Lol, no worries mate. See you out on the road again soon. :)
Last night about 6:15-6:20pm, merging onto the Westgate from the 4-lane onramp at Docklands, spotted a maroon S1 R33 with black or CF vented bonnet and Qld plates (391-***). The Festiva that was in the lane between us would have had a nice double-dose of RB goodness, lol.
Shortly after that spotted silver R33 SHYSKY on the Princes Hwy.
Was Heading home a ways with a Really clean & looked after Blue 32 GTR Heading down Kingsway exit & Nepean highway at 3 o'clock today.
I thought it was awesome How it was quiet and dignified as opposed to being "BRAAAAAHHHH LOOK At MEEEE!!" although
being able to smoke pretty much anything that was on the road it has the right to :closedeyes:
Not quiet and dignified was the Tradie in the XR6 Turbo getting on the revs being angry with the Sunday drivers lol
Jeez they're out today! ... Black Four door 34 with P plates up blasted past me at the south end of the Frankston freeway and was going nuts jumping around and in general getting up to mischief. I thought it was funny. He slowed down up the North end of the freeway... clued on... i assume thats because he knew that's where the fuzz like to hang out :pirate:
UNR33L (Leigh) on Burwood hwy/Templeton Rd around 11:45am, would be very suprised if you didn't see me.
haha saw ya, didn't realize you were behind me I was half asleep at first, driving zombie mode so got out of your way :P
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
