Grey? Seen it before
Keep seeing a white r33 parked in eltham near the Caltex... not you is it?
Yar it was gray. I do have a white r33 but no it's not me, I was only in eltham for work.
Also spotted a clean white r34 four door with sau stickers on russel street (I think) in the city
red r34 with black aftermarket wing on springvale rd (somewhere between high st rd and bwd hwy, where i turned off) - probably a few minutes after 5pm.
looking good mate (if you're on here), but i think your left brake light is out. wanted to let you know at the lights but unfortunately was one car off, so couldn't :P
spotted a girl in a white r33 gtr in the right turning lane on frankston dandenong rd around 5pm, think the number plate was NOODLE or something like that, i apoligise if i was wrong. i barely saw the car with the corner of my eyes while i was making a U turn
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
