  • Replies 103
この エンジン わ いくら でした か?
ちょ たかい でしょ、ね? はちじゅまん?
おい!いま わ あなた の インボクス チェク はいやく。
How much did it this engine?
CHOTA? Today, right? YUMAN CHIJI is?
Hey! Now it is your INBOKUSU CHEKU and quickly.
For some reason i dont think that translated correctly.
yeah it should be kono engine wa ikura desu ka? (how much was the engine). cho takai desh yo? (a bit expensive wasn't it?) hachi-ju man yen? (80X10,000 yen?) oi, check your in box.
Dyno sheet, Baron. Dyno sheet.
coming soon. we have some from when it was tuned, but they use an old school bosch chassis dyno which must be measuring power in the german unit for mechanical perfection cause I have no idea how to read the thing. it's farken weird, it looks like it was plotted on special paper, like chart paper with one of those things like they have on lie detectors tests scribbling out some kind of graph!
eventually I'd like to see a nice agressive tune and some cam gear adjustment that would uleash the potential within. :D
That is the greatest thing I have heard all week.
I hope you thrash the crap out of it, that engine is just begging for it!!!!!!!!!!!!
P.S. Does anyone have towel? I may have soiled myself.
Awesome 32 Richard :P
As always thanks for another absorbing thread. Great to see you're taking the time to do the build right.
Love the simple and clean finish you've gone for. I'm a big fan of that style. BTW changing to 34 rims was a smart move, it looks sharp :happy:
I hope you get many km's of joy after all the effort & Yen :ermm:
Cheers
Edited by R338OY
thanks guys, sadly for me I can't in all honesty afford to keep it too long so it will be up for sale soon. hence the reason why it hasn't really been driven in anger by anyone yet, saving that honour for whoever takes it off my hands. we even went to the trouble of getting the rev limit re-set to 3,000rpm before shipping to ensure no-one took it for some un-invited fun! I'm hoping when I do sell it that it will go to someone on the forum or someone I know so I know it's in a good home.
to give an idea of how well this car has been treated we even have two set of floor mats for it! a mint set for just sitting in it and another full set for driving. both genuine nissan mats.
I have a slightly more track oriented GTR with cage, harness, race seat and race suspension set-up and my new engine for it arrives in a week so my focus is back to that for the moment. don't worry though it will be every bit as nice as this one just a little different, but lots of the same parts and know how are going into it.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
