we finally have a good 999 car.... eddie decided using other people's crap was too hard so he purchased quite a nice Emo 8, all prepped up :)
i drove said EMO 8 tonight, it's no GTR but nun the less not bad for an EMO
Ignition Module Needed:
Melinda's car (GTR #832) has new engine fitted and dynoed today by the great guys at GT Auto Garage, but it shit the ignition module half way through. finished the dyno with a lend from a customer car, but had to give it back. I have exhausted my contacts in Brisbane, and will try Just Jap tomorrow morning and see if Steve can bring one with him (if he hasn't already left?)
We are leaving for the drive down tomorrow night though, and would be good to know we have one before we set off..
Anyone with any ideas on where to source one
Cheers
Paul
0433 73 44 55
Edited by poolheaters
Cheers
Paul
0433 73 44 55
yeah the Just Jap guys have not left yet, give them a bell I'm sure they can bring another spare down.
Thanks for all for the replies guys, great response from the rally community!
We have a couple of leads to chase today in Brissy and and I'll ring the Just Jap guys today as well. Also a couple of modules waiting in Hobart if we need them..
Cheers
Paul
I'm arriving in Lonnie saturday. Will have the customary piss up at the Olde Tudor saturday arv/evening.... and this time, Dicky Johnson is joining us :)we finally have a good 999 car.... eddie decided using other people's crap was too hard so he purchased quite a nice Emo 8, all prepped up :)
I heard it comes complete with Bibles and Holy Water.....
A little off topic, especially considering the timing, but I'm going to Tassie with my car (on the boat) in the couple of months. I'm staying at Coles Bay for a couple of nights and won't be straying too far once there. I've got 3 hours to kill on arrival before my wife flies in, and then there is the journey to / from Coles Bay plus any worthwhile detours I could consider. I'm looking for some fun driving roads and thought if anyone would know it'd be the Targa crew.
If you've got any suggestions then perhaps PM so we can keep this thread clean(er).
Cheers.
That's easy Nick, take a run up the east coast to The Sideling, or any of the roads around Elephant and St Mary's Pass. Download a Targa Map and cross reference it, not hard to find great roads in Tas! :D
Edited by Marlin
Cheers
Paul
I have one I am not using for the next couple of weeks in Melb if you need it. Pretty sure it's at Racepace in Bayswater if you can drop past there and grab it.
Drop me a message if you need it i'll call ahead and make sure its there.
Yeah they're not exactly rare Paul, I'd assume you'd have one by now?
Yeah you wouldn't think so Woo but trying to get a good one locally yesterday was near impossible. Thanks to the JustJap boys and the Hobart connection at Moonah Auto Spares, there will be a couple waiting for us in Launceston.
It split the front turbo oil drain pipe on its last dyno run today, and had to get that from Sydney too, not a one to be found here..Hopefully that's the last of the issues?
Leaving at 5.00 in the morning, see you all in Tas
Well it's my module your getting from Moonah Auto Part's, Troy's taking it and your fuel drum's up to lonnie on friday
if you need anything else my car is apart on the hoist, so you can borrow most thing's, it's kinda like Noah's ARK
there's 2 of everything in my workshop at the moment, 2 engine's, 2 gearbox's, 2 diff's, there's shit everywhere...
Thanks heaps Burgz. hopefully we won't need it but good to have a spare. The one JustJap Steve is bringing down is straight off his car & proven good. He has changed to a R34 setup bacause he was sick of these failing all the time. Catch up with you for a beer down there..
Cheers
Paul
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
