the 'business relationship' is that Nitto is a brand division of Toyo in the USA (& Canada), with the marketing advantage of being 'made in the USA'.
http://www.toyojapan.com/cgi-bin/column/data/release/1119852599.html
Did Nitto North America's 25 staff develop an entirely new semi slick construction and compound and sell it cheaper than the parent company's R888, or is it built with Toyo technology and differentiated by a new look for the North American market? I'd be looking for any evidence that it is different...
My NT01's are clearly marked 'Made in Japan' Harry.
ah, well there you go. So they even come from the same place as Toyo R888s! I assumed they were made in the USA. As the Toyo release says, Nitto are just a brand of Toyo.
Ok I tried, I really did. But by turn three, I'd fallen asleep. Sorry Brah!
agree. plus watching his face in the rear view mirror was putting me off my lunch too...
Still does no mean that both Nitto and Toyo use the same compound or even that they are made in the same factory. For example, Toyota own Diahatsu yet both make their own distinct products.
balance of probabilities is strongly against you mate.
There's absolutely nothing to suggest the difference in the tyres is anything more than tread pattern. There is evidence that they're the same - eg Nitto are just a brand division of Toyo, they both use the same pic used to show their construction, they both have same treadwear, traction and temperature ratings...
whereas the only thing to suggest there is any difference is you saying there might be.
And Daihatsu isn't a brand division of Toyota.
anyway, that's enough off topic from me...
Edited by hrd-hr30
daihatsu a division of toyota? nitto and toyo not the same thing? next time your messenger comes bringing info... shoot him!
PS toyota own half of daihatsu but they are separate companies. nitto vs toyo on the other hand is more like comparing LEXUS to Toyota. as in nitto (just like lexus) is a made up 'brand' to market their products in another country.
Nitto more likely than not does use a Toyo compound, it's just interesting that in the US Nitto > Toyo by reputation, plus I like to stir Harry and his bad handling Silsomething :D
Hmmmm,
was pretty close to buying a RX7 shell and commencing the hiding to nothing, but maybe I just save the pain and go back to the old girl.. Seems she isnt getting any love. :(
http://www.my105.com/ListingDetails/tabid/65/cid/559/id/5750/p/4/Default.aspx
^^^^ have rung him and had a chat, and he basically has suffered a wake up call to the financial reality of tarmac rallying. After having a 15k weekend at Targa West, while he really enjoyed it, to live the dream and go east he has realised might be a bit beyond his budget. So plan is to down size and go back to his old STI which he has kept and carry on with the club level stuff here in the west.
Am serisouly thinking about getting it back, just to blast around in here and maybe take it ina bit more of a time attack direction (aero and more HP) as originally planned..........
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
