the 'business relationship' is that Nitto is a brand division of Toyo in the USA (& Canada), with the marketing advantage of being 'made in the USA'.
http://www.toyojapan.com/cgi-bin/column/data/release/1119852599.html
Did Nitto North America's 25 staff develop an entirely new semi slick construction and compound and sell it cheaper than the parent company's R888, or is it built with Toyo technology and differentiated by a new look for the North American market? I'd be looking for any evidence that it is different...
My NT01's are clearly marked 'Made in Japan' Harry.
ah, well there you go. So they even come from the same place as Toyo R888s! I assumed they were made in the USA. As the Toyo release says, Nitto are just a brand of Toyo.
Ok I tried, I really did. But by turn three, I'd fallen asleep. Sorry Brah!
agree. plus watching his face in the rear view mirror was putting me off my lunch too...
Still does no mean that both Nitto and Toyo use the same compound or even that they are made in the same factory. For example, Toyota own Diahatsu yet both make their own distinct products.
balance of probabilities is strongly against you mate.
There's absolutely nothing to suggest the difference in the tyres is anything more than tread pattern. There is evidence that they're the same - eg Nitto are just a brand division of Toyo, they both use the same pic used to show their construction, they both have same treadwear, traction and temperature ratings...
whereas the only thing to suggest there is any difference is you saying there might be.
And Daihatsu isn't a brand division of Toyota.
anyway, that's enough off topic from me...
Edited by hrd-hr30
daihatsu a division of toyota? nitto and toyo not the same thing? next time your messenger comes bringing info... shoot him!
PS toyota own half of daihatsu but they are separate companies. nitto vs toyo on the other hand is more like comparing LEXUS to Toyota. as in nitto (just like lexus) is a made up 'brand' to market their products in another country.
Nitto more likely than not does use a Toyo compound, it's just interesting that in the US Nitto > Toyo by reputation, plus I like to stir Harry and his bad handling Silsomething :D
Hmmmm,
was pretty close to buying a RX7 shell and commencing the hiding to nothing, but maybe I just save the pain and go back to the old girl.. Seems she isnt getting any love. :(
http://www.my105.com/ListingDetails/tabid/65/cid/559/id/5750/p/4/Default.aspx
^^^^ have rung him and had a chat, and he basically has suffered a wake up call to the financial reality of tarmac rallying. After having a 15k weekend at Targa West, while he really enjoyed it, to live the dream and go east he has realised might be a bit beyond his budget. So plan is to down size and go back to his old STI which he has kept and carry on with the club level stuff here in the west.
Am serisouly thinking about getting it back, just to blast around in here and maybe take it ina bit more of a time attack direction (aero and more HP) as originally planned..........
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
