Yep Kel is off in the morning to do it mx5 style again.
And you can redrill those holes for sure....the knurls are only there to stop it turning when the wheelnut is going on, the thread does all the clamping work.
Thanks Mr "unf**kingsubscribed" :) Definitely dumber from reading that thread,.
EDIT: And best of luck to all those having a crack at TWP this weekend. Have a fast, fun safe one.
Just don't use cheap studs. Cheap studs have soft knurles and have a tendency to spin in the hub. And bind on the threads. It's no fun trying to undo a nut off a turning thread.
I'll be interested to see if kell only drinks 2 days worth of drink rather than the 5 days worth she drinks after TT
Edited by DJRIFT
Fellas,
little tech question. I have a minor issue where the front studs on the mazda are 12x1.5 thread and the studs on the floater rear are .5" unf. Ideally I would like to run the same thread/wheelnut front and rear. I guess the preference would be to go for the larger .5" stud all round. Have looked around and there aren't any studs I can find with the right sized knurl to be a press in option for the front hub in the .5" thread. Am guessing its not possible to get the knurling on the hub remachined to a bigger size (havent really looked into it) so my other option was to tap a thread through and go a screw in (loctite) .5" cro mo stud on the front. Any downsides to screw in?
Any thoughts
edit: seems you can drill new holes to the correct size (.007" undersize of the knurl) and press in new studs. Probably the answer.
just further to this Blaise, I suggest running longer than normal studs too. Look at long studs that drag racers favour (and some classes require). Using an open-ended nut, the wheel stud protrudes right through it, allowing you to easily see at a glance they are in fact done up, AND allows vice grips on the stud if you ever have a siezed nut.
^^^^ Cheers all. Was looking at the ARP Cro Mo studs. Figure they should be up to the task. Similarly woo was going to go a bit longer and get the quick start nose on them for nascar spec wheel changes :)
^^^^ Nice tip. Thanks. That will be the next thing to chase once the studs are sorted.
Seems i cant get a press fit stud to suit the mazda hub (shoulders are too big or knurl dia to big making the holes get dangerously close to the outside edge.
Looks like I will stick with 12x1.5 on the front but goa longer quick start nose cro mo jobbie and change the rear hubs to match. If that stud size is good enough for gazzilion horsepower GTRs it should be sweet for me. :)
Testament to a good YT cage. Driver spent a night in hospital (took his HANS off in the morning cause it was too uncomfortable), and the nav has a broken pelvis. But the doors still open and close! I'd hate to think what shape they'd be in with a shitty TMR bolt in cage.
^^^^ Hearing you. Just not the area you want to cut corners on. Bolt ins just should be an option for tarmac rally. Similarly, would not run without a HANS and side supporting seats. Unrelated, but I remember getting both front teeth knocked out as a kid playing hockey cause I took my mouth guard out for 5 mins cause it was pissing me off. Be gutted if you ran without your HANS and busted your neck or had massive head trauma. Bit like feeling like a tool for wearing your race suit at less than big events.....but would be a proper muppet if that was the event your car decided to burst into flames in.
And re the event, only managed to follow in the virtual world, but hats off to Rickards for what looked like an epic drive. And the captain for putting away all but the lambo. Farkin allright for a hairdressers car. :) Seems this fella in the 240z in classic can pedal as well. Pretty dominant drive.
Always like to think the best of other competitors... (I was one of the gullible f**ks that thought Lance Armstrong might have been clean... ) i reckon it seems they are relative new comers to the sport. (as I am) I reckon you definitely find more speed as you get a better handle on where to find the speed easily and where it isn't worth trying for it. Maybe just finding their mojo a bit. Seems they had some good pace on seasoned campaigners like Todd and Garwood. No doubt it must be a nice bit of gear as well. Be interesting to see if Rex comes back for TT.
Yeah sorry, didnt mean to insinuate that. To be honest with the very open rules in classic, I am not sure that you can :) But must have been a surprise to some of the more established crews. have definitely raised the bar. I am guessing just a new crew that have really taken to it. There must be a heap of undiscovered talent out there.
Edited by Darkside
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
