Better, e85 is cheap torque gains also, which are even harder to come by. On it's own the best mod you can do on a turbo car, if you can live with less K's to a tank, and have a pump locally.
The GCG is a bit of a mismatch turbo, mainly due to being stuffed into the stock housings. Best bet is to pick up a proper Garrett GT3076 and sell the GCG off, but then you need a new dump, intake, lines, external gate perhaps... the list can go on forever. Do some research before you jump in, as jumping up in power again from there may force you to replace all those parts again.
  • 1 month later...
Should i be a bit worried about using Caltex E85 when it was tuned on United E85?
It did have about 8 dollars worth of 98 in the tank when i filled it up with E85 before the tune though.
I run eflex occasionally on long runs, I didn't notice anything out of the ordinary. I think it's only around 4% richer than United I worked out. Still more accurate than a carby. ;)
It also means the mixture will be rich as a result of increased petrol content, which will compensate for lower octane.
When has richness ever compensated for lower octane? I know what you are saying in terms of it being a tad safer because its richer but that statement itself is wrong...
This topic has been brought up many times, discussed thoroughly, and concluded by enough people who know SIGNIFICANTLY more than I do on the subject that it will make sweet f**k all difference when it comes to any risks brought on from ethanol content change and subsequent RON change.
Just wondering what spark plugs heat range you guys are running?
I have my S14 SR running on E85 making 280rwkw on E85 and are playing around with plug choice.
some say run a cooler heat range some say run the standard 6 heat range?
I have tried going from 6 to 7 and even colder plug in 8's.
What are the yays and nays of these different temp range? Apart from the starting up difficulty with the colder plug what else is to be considered?
Yep, here's a paper that backs up what you're saying.
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CDUQFjAA&url=http%3A%2F%2Fdspace.mit.edu%2Fbitstream%2Fhandle%2F1721.1%2F69496%2F775670245.pdf%3F..&ei=am8vUaHdBYj88QT6xYGQDQ&usg=AFQjCNGwXDKnWr9zhWOVwjfkHqrqsQZSyA&sig2=PlJh-ScUjRaOaCrwqunmpg&bvm=bv.43148975,d.eWU
Basically once you get above 40% ethanol content on a port-injected engine the detonation resistance of the fuel plateaus. So at minimum E40 "should" get you the same benefit as true E85.
Disclaimer: not an expert, read the full paper and decide for yourself :P
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
