made 427.9 kw last nite on 25 psi dropping to 24 and with a couple of little misses
built 26
272 cams and asorted head work
t88-33d turbo
for some reason power starts to drop off abit at 7250rpm instead of still climbing
built 26
t88-33d turbo
What is the T88-33d like; full boost when and what size ex. housing?
its laggy but its soo fun on boost, i love it. it drives around normally quite nice in my opinion
full boost at 5900rpm all way to 9250 redline
18cm exhaust housing
i had gtrs' before i got the motor built and its alot more fun to drive. love the sound of an open 60mm gate that goes straight to atmosphere
Yes; that is late on boost. I wonder how the 15cm ex. housing will go at improving it? If you are not fussed guess it doesnt matter.
I think you should post a video though so everyone can enjoy the open gate to atmo :)
im not spending any more money on my engine. im happy with how it is
just gotta get my brakes upgraded and thats it, car is complete
no vids of runs. fone died at work and had nothing to record with
What setup have you got for cracking the 4's?
I'd happily take you if mines ready, it's pretty much impossible to be there though cause it's not long enough to get the work done. If a late night happens on Saturday and it's all good I'll pm you. In saying that I'm expecting to need a lift aswel so tgeres no need for the supra
Cheers steve..
The current setup is a built 26 ..forged pistons,stock rods with arp bolts, N1 pump with nitto gears,heavily ported head with JUN 9.5 268 & large valves, ported & ceramic coated stock exhaust manifolds, modified hks 2530's ,R34 dumps, id2000's & haltech platinum pro.
If 2 bar of boost doesnt see it crack 400 then E85 should do it.
It's nothing mega, that one will come later..full counter 2.8 crank,pankl titanium rods & the head from the current one.
Cheers steve..
Yep confirmed, zero chance of it being there
Pankl rods? Oh pics please! They're no doubt obe of the best available. What stroker do you want?
If all else fails, add boost :P
built 26
t88-33d turbo
when are you going to WSID? i wanna come watch :P
the drop in the top end might be cam timing, the tuner might have it setup to help with response but will suffer in the top end a little.
my old GTR 419kw had the same little misses your talking about, boost seems to blow the spark out especially 25psi
I like your attitude!
That's where most people go wrong...... go with what makes you smile! not what spools up 100rpm earlier...
i wont be going up till early next year. heaps busy with work atm and other things in life so that will be the earliest.
knowing me tho ill probly do a few more tweaks here and there before i go, i just cant help myself.
looking at breaking into the 10s when i go
even with the power.... 10's aint as easy as it seems.
thats right, heaps of people told me it would be shit to drive but i havnt had a single problem with the way it is.
there was only 600rpm difference between my gtrs' and the t88 for full boost so im not going to let that bother me at all.
maybe later on if i want to track race ill go low mounts again but untill that day im not looking back
yeh i know. i went 11.4 with average launch and bad 1st to 2nd gear change. that was with 400kw
so since thsat have had another tune new fuel system and os giken gearbox
Might be 600rpm difference between your GTRS' but full boost at 5900 is at least 1800rpm difference between most T04Z results on a 2.6L
and making the same power at the same boost...
i have a to4z and i think i get full boost just before 5000 , that's on a 2.6L with fogies and complety stock head.
personally i wouldn't be putting a to4z on any thing with out some serious head work and preferably stroked a bit.
i.e i maxed out my 023 bosch fuel pump on 16psi lol , that's not even in the turbos affections
you mean efficiency? ^^^
T04z should be running a .82 rear housing, mine had a 1.0 rear and was on song at about 4750ish
mine made 419KW on 25psi,
ive heard stories of ppl making the same power with a .82 and less lag.
T88 would be pretty sweet as it ramps onto boost and then fry tires,
yer i have the 0.82 , any idea why mines a tad more lagy?
i have std head , do u have a std head?
cant remember if i posted it in here ages ago but mine has gone 585rwhp on 18psi and 98 pump, t04z, 2.7L, extensive headwork and big cams. It also made 605rwhp on 22psi but was misfiring so backed off early. I ran 11.3 @ 124mph in a 1740kg car when it made 520rwhp on same dyno.
The new car in nearly ready to run again with this engine so looking forward to seeing what it can do.
Yeah mine had standard head. Just drop in poncams and cam gears.
I havent hadthat car for about 3 years so my memory ofthe lag isnt the best.
Just to rub it in guys my current (near stock)GTR has a whopping 285kw and runs 11.7.
Just to make u feel glad u spent all that money to gain half a second like i did in my last GTR ;)
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
