Alright it's not a GT-R but for a laugh...
SR20DET
Forged bottom end, cams etc. Still a 2 litre, ID2000's 3 x 044's
Precision billet 6265 turbo
It has 20psi @ 4500rpm
486kW at the rear wheels @ 39psi on E85
Ran 9.6 @ 144.6 on radials with 453kW so keen to hit the track again
No nitrous
SR20DET
No nitrous
I call shotgun PJ. U know ur allowed passengers now at WSID. We might have to lie to them about u running slower than a 11.9 ;)
just like u used to keep sneaking in and running under 10.9s
+1 for the 400kw+ club
680 4whp ( on a hub dyno ??? ) what ever that is ? don't want to start a dyno war, but I'm sure its over 400wkw
HKS step2 2.8 stroker, full counter crank and rods kit, CP pistons.
Garrett TO4Z .84 rear
, Jun 272 in and ex cams, 10.8mm(?) lift, special retainers and all the jazz needed to support the cams and high revs, heads extensively ported.
Current street setup with wastegate plumbed back into HKS 4inch exhaust
1000cc HKS injectors,
Motec M800 ECU
Motec M800 ECU
507awkw
there was some talk of lumpy cams earlier in this thread, this is the idle of the above set-up jun272's
I fell in love with it..
its amazing how much poppier big cams sound in a 2.6ltr - the 3ltr muffles most of that sound
Also did you actually port the manifolds or extrude hone?
I'd like to get mine extrude honed to see how much difference there is
we spoke about this before stevo - i wanted to have mine done but not after the quote i got for over $1000
ive got bigger cams than that and people reckon it sounds like a rotor at idle. Even a rotor workshop owner told me lol. Ill post a sound vid when its actually running again.
in 2021 :D
its very close to being ready to go, just need to wire up the new ecu setup (only recieved that today) now and the car loom, done a few changes and its actually in a bloody gtr. Engines been sitting on a stand for over 2 years now while building the car up. I might paint it green too ;)
Bullshit!
Dan pulled up at the servo and some dude asked if we had a 13B in it. Coulda been blood if I was there. :blush:
F#@king hell Noel! I knew you had a nice GTST but that is insane. Top stuff!
What cams do you have?
Running tomei 10.25 lift with 270 degree inlet and 260 degree exhaust Dave. Going in tomozz for our first e85 tune, should be interesting.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
