Series 2 you mean?
There is no gearbox other than the RE5 that bolts up to our orphan, I need to swap the sump so the bolts line up on the 350x box, and the starter fits. There is a lot of mechanical work before I even get to the electronic side. :/
The 350S was a series one car...
Sounds like a lot of work. Don't envy you. Starter gets moved to the other side, right?
3 times what I spent on the 350z box though. To fit the R34 gtr box you would either need the floor pan modified extensively and a new gearbox support made, or the transfer case would need to be spaced out 200mm or so off the back of the box.
Add that to the adapter required for RB to VQ, and buying a new twin plate Nismo clutch... I just can't afford it. :/
Floor pan mods are fairly straight forward, but tricky when you have to remove seats, carpet, sound deadener, looms, and then fit them all back...
Gearbox support is fairly straight forward, as a hybrid can be made between the GTR/Stagea
Custom Tailshaft required ($$$)
Gearbox Adapter would be a PITA to make from scratch, but can be bought for $,$$$...
You would have to use the GTR drive shaft to the stag diff (or get a custom one made)
Would take a fair bit of time and dollars including the purchase of the box itself.
Not to mention getting the ATTESSA clutch oil pump and all the other stuff working.
Why not Rwd ?
Massage the guards to fit some wider rubber
350z box and id say twin turbs if it has created more space presto
The rear guards will actually take quite large rubber; it has always been the limitations in the front (to keep ATTESSA happy) that have dictated the rear tyre sizes.
IIRC, several years ago, whilst auditioning rims; bbenny had 19x10.5s under the rear of his.
The only reason they didn't stay, was the issues with the ATTESSA going bezerk due to rolling dia differences with the front 19x9's & mismatched tyres.
Daleo 10.5" rear bags....
Interesting...
Well then
Apart from having total control being manual.transmission.
Myself the idea of a motec harnessing the full potential of the vq25det without that killjoy auto tranny ecu would prove irresistible.
Want to buy my 350z box and Nismo twin plate coppermix clutch now Toby? :P
I will get around to it eventually, one day when I am bored. Still searching for manual V35 interior parts... I am contemplating just using the 350z console and adapting the handbrake to work. Not sure what it would look like though.
I've always thought if I decide to heavily modify my PNM35 I'd just go RWD and 350Z manual box, but you really have to weigh up the cost of getting the car to a state you're happy with in terms of fit and finish vs the cost of sourcing and bringing in an Autech 350S. I guess you guys in Aussie have to worry about complaince though so it's probably not an option for you.
The nice Autechs fetch a tidy price. And your stuck with the shitty dash, not our nice one.
The cheaper ones are flogged out, I think its much better getting a S2 and converting. Even better if you have a RWD S2 car.
  • 3 weeks later...
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
