+1 for the above - He really will.
Is that new thing suitable for, I dunno, some guy wanting to run a low mount smallish turbo at 28psi on a RB28 auto sedan? ;)
LOL you sir would likely be happier with a straight SS2.
However, the new highflow profile amazes me, and a PU version of that (.82 T3 rear housing) might just rock socks on your motor!
Got some feedbacks from the ATR43SS4 built as a Ford XR6 BA internally gated bolton turbocharger. Its doing 408rwkws on 18psi P98. I think the turbine end is maxing out, it really needs a large external gate for more power.
LOL knowing the Ford Barra thats probably revving to 6,000... Meaning its on full boost preeeeeetty close to 3,000.
Thought I might just let everyone know.. LOL
Just a heads up to anyone who wants to go bigger then SS2 and go low mount, think again :P
my SS2 JUST fits, But it does fit, Engine is in the car now, cant wait to see how it goes
It's not far off from what I can tell. We did some trial fitting and working out exhaust/wastegate configuration on the old engine.
Its probably slightly different but not a whole lot off. But I'd say the stock side mount manifold wouldnt be quite as tight
I cant remember what Stao's Brae manifold is off the top of my head?
Nice. Does that manifold mount turbo in exactly stock location?
It's pretty much the same deal with the stock manifold, my SS2 fits but only just (on an R34). The actuator to chassis clearance is 1 or 2 mm so it's tight. Also due to the overall length of the turbo the intake and OEM intercooler piping will need some customisation. For a direct bolt-on a highflow is the easier option.
Wow! Looks pretty cool, but pretty intense - I always kindof liked the idea of a low mount setup but after seeing a couple I'd say it'd be a pain if you had to change turbos haha. Out of interest, depending on what brand you go you can get a MASSIVE amount of power out of that size frame - even the 900hp FP3794HTA turbo uses the same housings as you have there, so I am sure inside and outside of the HG range there is plenty to move up to if you end up needing more power than the SS2 can give you.
Be good to see results :)
Im trying to keep it as legal and non sus as possible while still chasing decent power.
I know the 6boost hardly looks stock but at least theres not a turbo hanging up top lol. Power steering line is fouling on the joiner off the comp housing. Can kinda see it in the first photo. Thats about the only issue
Stao..how about you make one with a Gt37 style turbine. like i said in my messages
a while back ...the rb30 boys would be able to use that aswell...Ill even test it on a mid 10 sec car..lol
cheers
darren
Haha, i missed the end.
ATR43G2.5
Keen to see how it goes I have g2.5 and currently underwhelmed with my result and unsure if it's turbo or something else that is lacking.
What was your result and why are you underwhelmed?
250rwkw. Hits hard about 3500/4000 which is good but after that the power just flattens out has no extra go at all pretty much gets the 250kw at 4500 and doesn't climb from there
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
