have you been on the dyno with that set up Johnny?
Not yet, but most likely next month after the track day.
It's pretty fast I can tell you that and will take more timing. However, I feel it's safer to ram in more boost run lazy timing. I'm feeding it 1.6bar now :)
completely stock engine right? you might be better off leaving some timing out of it even if it can take it happily. Still it will be fun to see how the dyno goes. What clutch are you using? I'm up to replace mine soon
yep, unopened and about 300 000kms on it (clock says 140 000 but I'm skeptical about it).
I'm running a funny clutch actually, it started life off as a NPC Carbotic Push Clutch with a 1.8 ton pressure plate. After 1.5 years it started to slip so I pulled it out to get it checked. Turns out bearing carrier was incorrect causing the clutch to be disengaged every so slightly all the time.
So got the pressure plate machined and clamp reduced, the correct bearing/bearing carrier put back in and I decided to go for a Xtreme Racing Disc instead. It's lighter and also easier to drive with.
So now I've got a NPC pressure plate that has its clamp brought down to ~1.6 tons with a Xtreme Clutch Disc that was tricked up.
Car drives like a Yaris.. you could press the clutch pedal with 4 figures.
GTR Dynoed today. it made 308rwkws with 16.5psi, injectors maxed. I will be upgrading to ID 1000s before the next dyno tune. In comparison to Rb25det, they seems to be making the same power except Rb26 engine is 300RPM laggier without the advantage of VCT. Car however is pretty good to drive. I will be evaluating the ATR43 Alpha series shortly which should have similar effects of having VCT.
Dyno reading shown comparison between SL20.5 V factory N1 turbochargers on same boost level.
Old fashion engineering for a bit of laugh: Making an window seal plug out of solid piece PVC plastic:
Not really. The SL20.5 is a common turbocharger used for Rb25's external gated applications. So I would like to see the differences in between the two engines. The built purpose is for the further developments on the SS Alpha turbos, which I'm concentrating on making a responsive big single.
  • Like 1
While I'm in here, I have twin GT-RSs on my RB2630 and the rear wheels are choking it up top, is there an option to fit a bigger turbine wheel ?
Just a quick update. I'm in the process of making a 55mm exhaust wheel for SR20det motor. That is a mm a side bigger then your GTRs turbine all around. I will doing some evaluations ready, they should be the solution for your current issue on the Rb2630 and pickup more mid / top rang torque also.
The new 55mm version of our ATR28G/SS 1x exhaust wheel is evaluated today. I have fitted with with a G2 71mm compressor for this evaluation.
We've started with 16psi and boosted it till no more power can be made:
272rwkws is the peek and good enough to make 200rwkws @ 4000 RPM on a SR. Pump 98 fuel is used.
Compare to standard G2 with 53mm turbine:
Thin lines are from standard G2. Note the boost taper behavior is minimized pre 20psi. New turbine wheel is 200RPM laggier, but managed to hold power longer after 6500. We where also been able to run more boost that made more power. My exhaust manifold did not turn red during any of the runs above either, which did running standard 53mm turbine. It result was similar to as if the G2 was externally gated.
We can also notice that the compressor wheel is reaching its maximum efficiency as more boost is added, that is indicating that an larger compressor wheel can be used working with this turbine. I will be using our SS15 compressor for my next evaluation.
There is about 14kws differences up top at identical boost levels. I have made a marking on graph below:
So by using two of those turbine wheels on the RB2630DETT mentioned, it will significantly drop your back pressure in upper revs, and hold power band for longer.
  • Like 2
Thank you that that is very interesting, I am pulling motor out over Christmas and amongst other things want to upgrade turbos so I will have figure out extacly what I'm going to do, I also want to go a bit smaller with comp wheel in Billet, 67-68mm I think should give same flow but better response
Your GTR, have you played with cam timing yet ? if not try 6deg adv on intake and 9deg ret on exhaust :thumbsup:
  • Like 2
9 degrees is a long way to shift a cam. Are you sure? I'm looking into this at the moment because I'm in the process of putting my engine together still.
with factory cams most people say around -2-4 degrees on the exhaust and +4-6 on the intake.
I just want a good baseline to start with really. What is the consensus these days?
in case it matters, the turbos are HKS GTSSx2 and the engine will be around the 9.3:1 CR but I don't know if that will make much difference to optimal cam timing.
edit: sorry Stao for hijacking your thread
Edited by Blackkers
^^^ if you ever got a ride in the car, you'd understand.
This man he knows :)
My 32 is set purely for response and my exhaust cam is a fair bit more then that, that setting is what I would consider a good allround setting for response and top end without the over the top anger my 32 has
  • Like 1
The settings are for stock cams, 32 and 33 are same 34 is different timing, anyone into moding cars should know you always find corrected 0deg and start from there
As for bottom end I fail to see how it makes a difference as every revolution is still 360 unless that changed while I wasn't looking :P
Not sure if trolling :huh: Either way, pretty sure we had a yarn on this very topic almost a year ago you were talking camshaft design, I remember wondering if you were really listening to my side of the conversation or not. Perhaps I have my answer to that? :whistling:
Production line style tuning can work it lots of cases, especially if applied to identical setups but I tend to be a bit more fussy/cautious about it and prefer to not tell people or apply rules blindly to every setup everywhere without some forethought or testing to ensure things are definitely going to turn out the way intended - but that is just me. The car would at the very least need to be retuned to suit a drastic change like this, imho.
It was a suggestion, Dan.
Really, who would change cam timing and not have the car on the dyno?
Heaps of people. Have you seen the crazy shit some people do on here? ;)
  • Like 1
There is an industry relying on people doing that kind of thing to earn their money :D
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
