few bits to check on:
3inches or bigger Metal induction pipe with Pod filter.
Check pressure drop across intercooler
3inches or larger turbo back exhaust, all flanges has to be in 3inches, Cat has to be in 100 cell, no cat gives the best result.
Tension up the actuator rod.
Further update. This is the ATR45 SAT version for RB26, I've trailed the ball bearing version, and it have made a very slight increase in response. I'm hitting the MAP limit for the Haltech ecu, will be installing an 3 bars maps sensor shortly.
Result against Standard Bush bearing model:
Also running against my factory twins:
Any decent tuner would have dropped the exhaust after the dump...
its the first port of call after an unexpected result.
Edited by Missileman
He sure did drop the exhaust.
The catco 3" metal high flow cat was brand new and installed by dvs. Hence why he dropped the muffler only. Jjr dump front pipe also 3" bell mouth brand new installed by him.
Unigroup reckons even new cats can cause restrictions.
We will see tomorrow
I'll keep you all updated
Edited by Therealsandybang
That's what I said. But I have to go through the detective work with the tuners which is a costly and painful process
Although they are both great to deal with.
I seem to remember 2 threads where there was a low power output, one was the GTX3067 thread and other Hanaldo's thread, correct me if im wrong but I think both had return flow intercoolers and JJR dump pipes..
Edited by AngryRB
  • Like 1
Some intercoolers restricts, and I've found that with my stock GTR cooler as well. I've posted few examples here, Do a log with boost sourced before the cooler and see if that matches the reading on the sheet.
GTX3067 results were with return flow cooler, but dump is custom 3". That was thought to be an issue, but changed with zero difference.
I'm interested to see results of this investigation here.
Also how good does the adaptronic go compared to the likes of Vi-Pec/Link/Haltech ect in plug/play versions ofc. What can you do the Adaptronic for $$$'s wise with the sensors ill need and everything to just plug it in and set it up to go haha
I personally have not used Vi-Pec but I can comment on the Haltech & Adaptronic.
Haltech is more refined, has enough drivers to run full sequential injection & ignition where as the adaptronic is semi-sequential due to the lack of output, but Adaptronic has native serial input for most widebands and also direct flex sensor connection where as Haltech you will need to use an analog 0-5v input and if you want more inputs you'll need a pricy IO expansion box where as the adaptronic just pull off the cover and hook up additional sensors. Also adaptronic has a built-in 4 bar (43.5 max factoring in 1 bar atmospheric pressure) map sensor where as a Haltech has a 3bar (29psi max factoring in 1 bar atmospheric pressure).
If it boils down to features and price, Adatropnic hands down. If it boils down to software refinement and out of the box driveability from day one I would go Haltech.
You dont need a Dyno to check for an intercooler restriction, its cheaper to but another boost gauge or just move the boost gauge pickup to ore intercooler and see what pressure reads.
Gentlemen,
Did decat test. Ran 235kw at 13psi with no det on Unigroup dyno which apparently reads a bit lower (that's another argument).
Still losing boost from 17-->13psi.
Tao recommended pre loading actuator. Checked bov for leaks and did a run with it blocked off. Bov is fine.
They don't seem to think it's cooler yet.
Still some sort of restriction which is opening gate and preventing boost from being held.
Pull the circlip off the wastegate pin and check that there is about 5mm (half a hole) of preload.
Start checking hose clamps and silicone joiners.
I use a JJR return flow cooler and dump pipe, they are not the cause of your problems unless installed incorrectly.
  • Like 1
Hoping mine doesn't get same issues with the .63 rear, however should be easier to hold 20psi externally gated yeah?
My cooler is 510x250x70 , tube and fin, which is worrying me a bit, however can't go any wider due to auto spoiler motors for the flip down lip on the 31. Could go to a 510x300x100 probably max.
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
    • @GTSBoy yeah sorry i know thery are known for colors bud those DBA are too in colors 🙂 Green will be good enough for me
