No worries, still keen to see what you can come up with for the little motor, BTW that R32GTS-t I offered you has since been sold.
Edited by Missileman
Further developments. This is a Ceramic ball bearing ATR43G3SAT turbo that no longer require water cooling. Video shown turbo shaft rotation on RB25det Neo motor with engine start and shut. Super responsive.
Does that mean that you will need to idle down the car like an old truck after each drive?
Water and oil cooling has many benefits, unless the CBB is different
Just works like a normal water cooled bb unit. Except it doesnt require water cooling. Made for cars with oil cooled only turbo setups.
I will withdrawn the comment for now. It could be other causes, The bov is blowing air out, not sucking in.
You can run water to it if you want to.
Previous data shown boost curve is almost identical. but this one made more power.
Using same car with identical mods:
21U G3 high flow:
ATR43G3SAT CBB
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
