This is a prototype ATR43 G4 520HP CHRA. It runs on shortened bearings and weigh reduced turbine for maximum response. engineered to produce about 300rwkws at 20psi on .63 ATR43's turbine housing using RB25det engine with supporting mods.
The smaller one on the photo is ATR43 G1 350HP CHRA. Its made for 240rwkws with excellent street response.
Compare to ATR28G4 it has lighter turbine with shorter bearings. So it should have slightly better response. I might update this CHRA into the ATR28G4 once its been evaluated.
Turbine housing is getting made. I'm going to swap this 2x with my existing high flowing customers. probably Geraus and SS8_Gohan for some dyno and evaluation results.
For time been we will still be using proven ATR28 CHRAs. Price wise I don't know at this stage. depends on how much it cost to build the rear housing.
hi,
i skimmed through quickly but didnt find the exact answer i was looking for.
what turbo would you suggest is the most efficient/responsive for a Rb20(r32) wanting to make 240-250rwkw while keeping the stock manifold, but being externally gated.
thanks.
hi,
thanks.
i went with a ATR28G3 with 0.63 internal gate rear for my rb20... i'm looking for a tad more power than you
so maybe look at a ATR28G2
hook us up Stao :P:ninja:
we going to need new dumps? and am i going to have to run stuff in again... done so much friggen running in with this car :P
EDIT: so are you saying these will be laggier or potentially, they might be a little more responsive and make a bit more power?
Nice love the pointy wheel. Hopping to see the complete turbo and some results soon.
ps.
would this punch a whole on my foot if I drop it upset down? :ninja:
Edited by kwickr33
Today got the turbine housing made. It is .86 in a T28 which is equivalent to a .63 in a T3x.
It is bolt on to stock T3x manifold and 6bolt dump.
The Very first ATR43i 520HP G4 in T3 .64 Turbine is complete:
We'll be making few more different A/Red turbine housings in the next few weeks. We will also be engineering a 650HP profile CHRA to suit a .84 Bolton Rear housing.
Well stock turbo won't make 520HP. Bigger turbos will creat more lag. This is a G4 profile, made for 300rwkws.
We also have this in G1 and G2 profiles which are rated 350HP and 450HP. The G1 would have very similar response as the stock turbo to produce max of 240rwkws, G2 is about 300RPM laggier but but its good for upto 270rwkws.
Price wise This turbo is $1300 to complete. With normal Turbine housing which comes out in a Vband rear is $1050 internally gated. or $950 externally gated with a 5 bolt flange.
didn't i have a G2 originally? that was about 230rwkw at 15psi -
gotta remember, "most" people won't be bolting these onto built engines (IMO) - they'll chuck em on, run 15/16/17psi and that's probably about it. I'm only running a bit more boost because of E85, otherwise, 17psi would probably be my max.
will give you a call/email asap about the .63
Yes but that was in stock R33's turbine housing. Now they are running in a .63 T3x rear housing, The spec of it is very similar to a GT3071. So it should make around 260rwkws at 18psi of boost on 98 fuel
do you also make this turbo with an externally gated rear housing?
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
