Isnt the rpm on the right hand side in the second one?
Only road speed in the first one though, cant understand why they do road speed, much easier to understand and get a gauge of lag from rpm, maybe its a V8 thing...
No, it isnt RPM on the right hand side... its tractive effort/torque
and RPM is just a multiple of the road speed so if you want rpm you just have to find the right ratio
May be a stupid question but what does tractive effort scaling mean?
you have 2 lines on the graphs, power (with a scale on the left) and torque/tractive effort (with a scale on the right)
RPM/speed is on the bottom axis
Thats one way, an easier way is to reference both the maps together, both have kilowatts on the left at the same intervals but on the right one is psi the other rpm, so if you have a look at the psi map you will see that full boost of 18psi hits at a tad under 168kw, on the rpm map you go to 168kw follow that line to the right and you will see that full boost is at 6000rpm :down:
totally wrong
Ok I get ya, So do you know what tractive effort scaling means?
Does that mean they really did rev it to 8000+ or its just the way it displays because it overlays two dyno runs?
its a scale of the right of tractive effort/torque for the other curve on the graph... same as power scale on the right
it has nothing to do with rpm!!!
Edited by Cerbera
Hey there guys... Trent tuned my car with a boost leak and also my rear housing was maxing out with my folllowing mods were:
z32, 5 puk clutch, 3inch turboback exhaust with bashed out cat,walbro fuel pump 342,pody,740cc, pfc,return cooler,splitfures, g2 with stock rear housing,profec spec b II i have the same simular mods as Dav074's ! :down: oh and my plugs are gapped at 0.8mm BCPR7ES.. now my problem is.. how can i fix my boost curve?
Also i was thinking.. how about if us people get a re-tune by blocking off the stock blow of valve? so we run our cars with no BOV? would it hold up our boost better? or should take off our stock actuator and put in a aftermarket one??
Edited by geraus
Hey Geraus, how have you been. I could be wrong but it seems to be the general rule of thumb that you use an actuator that has a "base" preload or tension or whatever its called as close to your desired boost as possible. So if you want to run say 18psi get a 17psi actuator...does that make sense?
Someone correct me if I'm wrong.
You can try what I did and buy a HKS adjustable actuator which helps a TINY bit. The other problem you and I have geraus is our rear housings just won't cope hence the drop at the end. I had a talk with Stao on the phone a few weeks ago and we really need a .63 rear to get the best out of our highflows and to be able to run more boost with a flatter curve.
Keep an eye on your pm's mate cause I want to see what your profec is set at (gain etc) cause mines playing up.
Talk to you tonight
Hey dave! yeh man , Im using the stock acutator , What Tao did was he got a FILE and like shaved it down a bit and made it down more or something... And im using my Profec Spec B - II , Il give you the settings mayb 2morow morning... il be out tonight! and Dave! i love your car its lookin dam good brother!
And my other question is.. Do you reckon we should get another tune running no BOV? by blocking up the plate???
Edited by geraus
totally wrong
Since your the man with the answers explain tractive effort then.......
geraus/dave - look at my boost curve and urtwhistles curve as well. We both have G3's with OP6 rear housings, and we can't get flat curves. I reckon your car is fine geraus, boost curve looks about spot on for these turbo's.
Have I been conned?
no the dyno dynamics dyno have their own measurement for torque (they cant display true NM) and that is what your seeing on right hand side.
Edited by URAS
Thanks Guys Id hate to think they reved the car to 8k+ :P
I just had a quick gaze at this thread. I don't know if it has already been covered or not....but what do these high flows compare with it the cunrrent lineup of hypergear turbos? Example is the op6 rear high flow the equivalant to a tr43 or something like that?
I have a power fc, front mount, plenum, apexi boost control. Just trying to work out if I should go the high flow route or something like a tr43 or 44. Lost!
Most of High flowed turbos are running off a ATR28G2 CHRA. Their Wheels sizes are smaller compare to the xTR43x series to suit stock comp and turbine housings.
So it is very important to have a charging system that is balanced, oversized compressors cause surge and rise manifold pressure which force shift the shaft towards the compressor. At a point when over comes the engine oil pressure it will force the thrust collar to eat into the thrust bearing which will develop a shaft play over time. 20 thou and above will cause wheels to hit its housing and turbo fail.
With the xTR43x models they are not limited to the size of factory turbo housings. So we engineer the CHRA to a specific HP rating with matching wheels then choice the right size housings that suits different application.
Now the ATR43 has been engineered, They are a bolton turbo to suit RB2x manifold, lines, and dump. If you are chasing for high powers they are better recommendations then the stock high flow turbos and cost $500 more
ATR43 comes in 3x different profiles which is rated at 450HP, 480HP, and 500HP.
Thanks for the reply. Well i'm gunna go past the highflow and get a bigger turbo.
Help me decide please haha....
I have a 25det, power fc, front mount, plenum already. I want to go high mount with an enternal gate. Why you ask? I want a high mount setup purely because I love the look of it over a low mount, and I want te power. I will be getting injectors aswell and possibly cams to support the upgrade. I am currently running 196rwkw with a stock turbo on 11psi. I want a good increase in power, say a turbo capable of 250rwkw or more while still trying to have some response and not be a complete lag master. What would you recommend in a high mount kit?
We can build a ATR43 in .63 rear internal gate with 52T 76mm Comp which is good for up to 280rwkws with excellent street response. This turbo will bolt on to all your stock every thing except you need 90 degrees rubber pipe for stock cooler piping and a 3inch straight rubber pipe to connect stock intake pipe, Metal intake pipe is highly recommended.
Hypergear, do you have anything to suit RB26's either no or in development? I'll be looking for something in the next 6months (I hope)... :P
For GTRs we can only high flow your stock turbos. They will be in GT2860RS CHRA in Ball bearing or Idential ATR28G1 CHRA in sleeve bearing. High flowed turbos are good for around 550HP as a twin.
ATR28G1 Comp wheel and GTR factory Comp wheel
CHRA and reprofiled Housings
Assembled turbo:
Sure, but do you manufacture from scratch GTR turbo's? Or only high-flow stock turbo's?
Do you have any dyno graphs of high-flowed stock turbo's?
I'd definitely be looking at ball bearing, but would like more info around response and dyno graphs of any customer who has done it before with an RB26 to check if its right for me. To give you an idea, I'm looking at something that would provide power spool around 3-4KRPM, (close to stock) with plenty of torque, the end power result isn't important but around 300 or more would be nice :(. In other words the 2860-9 in Garrett terms sounds good to me...
At the moment the motor has been rebuilt but possibly with standard internals
Since, I can't edit, are we talking about this 2860RS (739548 - 5) which looks identical to a 2860-9 without the GT2560R compressor housing ?
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
