Is this one a straight bolt on with factory comp cover and factory dump pipe?
Any chance of getting a graph that shows power+boost with an rpm scale?
To Get about 260~270rwkws we can machine your stock comp and OP6 turbine housing then use ATR28G3 CHRA with a ATR28G3 with a cropped turbine and 14psi actuator. That should be ok for up to 270rwkws assume your Auto can hold it.
To do that it will cost $800 + $150 Turbine wheel modifications and actuator + $80 braided oil ine + GST = $1133
we will need roughly 5 days on it.
With ATR43 .63 turbine you can get similar power without having to crop the turbine wheel which get you lot better response. To high flow with the cost of turbine housing is $1230 + GST = $1353 including oil feeding line
Here's one with RPM in it (transferred the scale from Dr.drift's dynosheet):
Unfortunately the Boost analyzer at Phase auto got run over by a customer's car and currently broken. I have a sheet from Trent last week.:
cool thanks stao,
So the first option would require me sending you me entire turbo?
2nd option is that made completely of your housings? or do i need to send you a turbo of some sort?
ideally i'd like to not have to take my turbo off as i need the car to get to work. and then i can sell it later to offset the costs.
Can easily get my hands on a stuffed 33 turbo if that makes things easier?
you have so many different options im getting confused which one uses which housings etc haha
if there is not an option i'll just have to do it i guess. just sussing out my options.
seems to be turning over top end a bit early for a rb25?!?
With the top end. I'm suspecting that is due to the exhaust housing maxing out, or might be some thing to do with the actual engine. floor 4th gear the RPM fluctuated its way from 5500 RPM to 7000RPM. But it does not fluctuate on neutral. I’m not sure if all my boost were turned into blow by.
For 272rwkws I think this is the most responsive result I've seen. even compare to most of the high flow results. Looking pretty good, keen to see what it does on a healthier RB25 engine.
stao, any chance of getting the car to have a power run on another dyno eg. dr drifts or status???
would be good to see a full rpm pull up to 7000-7500 and also the torque/boost figures... the graph you posted seems a little wierd and says it makes 809nm which seems to be way too high
Hi Stao
would like to thank you for your excellent product and customer service mate. Little bit of background info: I bought a Hypergear ATR28G3 off Stao as an upgrade on my R33 RB25DET S1. Only looking to achieve approximately 250-270rwkw. The turbo is on the car now and on 14psi with power fc, 740cc Nismo injectors, splitfire coilpacks, greddy fmic, AM Performance exhaust, Bosch 040 fuel pump its making 246.6rwkw with a leaking exhaust. Ran out of time as i needed the car hence why the car was tuned with a leaking exhaust.
According to the tuner there is potential to get around 260-270rwkw with this turbo once the leak in the exhaust is fixed and the boost is raised. The turbo was a straight bolt on.
Highly recommended!
Thanks
Krishy
Thanks for the support.
I Probably go to status with the new R33 S2 in few weeks. I won't be taking my current R33's result very seriously, this engine's knocking with poor compression. Also this Fluctuating RPM probably indicated huge amount of blow by.
I have a problem with my turbo installation. I have included a picture of my old one and the new one so you can see the difference. It appears the compressor outlet on the high flowed one is rotated around too far and is hitting the exhaust manifold when I try to install it. In the picture I have a ruler across the face of the exhaust inlet on both turbos. On my old one there is a large gap above the compressor outlet, but on the high flowed one, the compressor outlet is holding the straight edge off the exhaust inlet. Can i simply loosen the bolts on the compressor housing and rotate it round to the correct position or will this screw something up internally?
Hey there guys, Nice nice, ive got basic mods like
full exhaust 3inch all the way with bashed out car
740cc highflowed injectors
power fc
z32 afm
pod filter
splitfire coil packs
walbro gss fuel pump
and a hypergear highflow with stock r33 housing atr28g2
greddy profec spec b II
and i got a tune from Trent @ status tunning doing 233.3 kws on 17.5 psi.
i wana reach 240-245 atleast... is this possible?
power fc
z32 afm
pod filter
from memory we cut tuning short on yours as it had boost issues (leaks or something) im sure there is more in it but have you fixed the boost issues?
Flargh:
You only need to lose up the 6 bolts under the comp housing. Then rotate it by very slight. then it should be fine.
Geraus to get 250rwkws you will need to run it on a OP6, or .63 rear housing. Or I can crop abit of the turbine wheel for better flow.
We also have .82 rear housings with the same bolt up pattern which I'm putting one on as we speak.
hmm, i re did my intercooler pipe and my turbo manifold 4 bolts. i made them tight. i'l bring it down soon just got a get some money hehehe . :happy: i'l book as well thanks.
Flargh:
Thanks mate, that's all i needed to know.
Hi mate. I'm chasing around 300rwhp or 200rwkw. Slightly not or less it don't matter. Don't want a lag monster and I don't think this power level really requires one. Looking at modified r33/34 turbos. Do you have anything off the shelf ?
Wish I could get a hks 2530. But funds won't permit
We can build you an identical spec sleeve bearing version of 2530 for about $1450 with oil line. Its ok for up to 230rwkws with super fast response. or we can sale you a high flowed R33 turbo for $1180 with oil line. should do similar sort of HP with slight less response.
g'day stao i'm looking at upgrading my stock turbo.
supporting mods are nismo 740cc's, fmic, fuel pump & ems stinger.
i'd like to take the rb25 to its safe limit, so around 330rwhp from what i read is reliable.
my question, is what would be the best for the street, i'm guessing a tr43 g2 with a .63 housing?
or would it be worthwhile going to a .82 housing ?
and aside from the oil line, thats completely bolt on yeh?
sorry about all the q's, i've been reading nonstop for a few hours and i'm a bit confused.
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
