We actually build a brand new turbo core with bigger wheels, then machine your stock housings to suit it. We only use steel turbine wheels. So are you actually getting back a brand new turbo inside your factory housings.
yup i understand that but is it possible to just put a standard size steel wheel in there, ie no machining etc?
Yummy.... $1300 basically... what kind of response and power am i looking at with this rb25 highflow ?
I would say around 280rwkws with high pressure actuator. full boost by 4200RPM. be just like this one here:
(Dynosheet below is running a normal 1KG actuator)
http://www.digi-hardware.com/images/dynosh.../atr43360hp.jpg
and No we can not get standard size wheels in steel.
obviously with supporting mods.
what psi was he running?
With the high pressure actuator will i be seeing better results ? than that of the 1kg one ?
small edit : Even tho i hand you a turbo with shaft play and all that jazz it gets fixed anyway correct? so i can go buy any turbo in hindsight and still get a brand new one back ..?
Edited by v8tzr
With the high pressure actautor you will be seen a lot more steady sort of line with out the drop. and will be making more top end.
Once high flowed you basically get a brand new turbo back in your stock housings so it doesn't matter if your current turbo is blown or with heaps of shaft play.
The old and blown CHRA in your stock turbo goes into the bin unless you want it back.
As someone from South Australia where the inspectors will basically look for any external changes from the factory turbo to defect you - is it possible that the external of a Hypergear highflowed RB25 (R34) turbo will look identical to the factory turbo? Are there any lines that require changing? Is it possible to retain factory lines, or is it a requirement to go to something else?
I'm guessing changing the wastegate actuator would be an obvious visible difference too - so despite performance benefits, it would be better to use an RB20 (10psi) one or keep the factory R34 (5psi) one to avoid Transport SA issues?
Well visually the high flowed turbo appears to be same as the stock turbo. You can use your stock actuator. Or we can modify your stock actuators actuation bracket to suit a high pressure actuator.
Few new projects and updates for 2010:
First of all few of you already know We've started developing VARA project in Mid dec 09. Which allows us to change your turbine A/R to what ever we need it to be. Means we can now high flow your stock R33 (yes your stock 2IU turbine housing not OP6) turbos to produce 270rwkws if need to. So we are no longer boxed by the flow limit with some smaller turbine housings.
2ndly as we all aware that smaller turbine housings gives us better response but not good up top. with our Variable Air Ratio (VARA A: actuator controlled) turbine housings. We can start off with a .42 A/R till 7psi and have it increased to 0.82 on 20psi refer to boost increase. Means you can have 300rwkws with stock alike response. This response is also adjustable with a bleed valve. This method has been used on few turbocharged Porches, we will be intergrating this into Nissans.
3rdly We will be building .60 compressor housings with stock size inlets and out lets. So people are no longer required to get any "Kits" as it bolton to your stock every thing.
I will be posting photos once I get back on the 15th of Jan.
Happy new year every one.
Hi Stao,
Can the VARA turbo housings be put onto one of your already highflowed R33 G2 turbos to reach the 270kw mark or do you have to redo the whole turbo.
How much would this be?
Hi Stao,
We can modify your R33 turbine housing for lot better flow which class under the PU highflow options. So basically yes we have to modify every thing on it.
The VARA is still under development at this stage. will be ready for public soon.
Excellent result Lowrb. Please post dynosheet when possible. Thanks
And will the response still be the same but with more top end?
Nah...you'll have more lag as per a bigger turbine wheel to create more power. More power usually equals more lag when it comes to turbo upgrades :rofl2:
Until Stao gets this VARA thing happening for us :domokun:
that's what I meant Birds, same response with the VARA????
Well that's the idea behind it anyway. I doubt it'll be exactly the same as stock but it should be much better than a straightforward high flow without sacrificing top end :D
hey stao just wondering say if i give u a HKS2535 turbo can u like put bigger wheels on it and like make the housings flow more if so how much? and what would the response and hp be like?
Cheers
Chi
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
