lol problem was .63 dropping. not .82. PU comes in both .63 and .82 depends on what people wants. Also I had a customer making 21psi to red line in .63 internally gated. I'll be seeing this guy's car on the weekend and should be able to sort it out.
We have an example here. SSGOhan here's running a high flow with a OP6 housing with a 20psi actuator. See what’s happening here? his getting 18psi with no boost controller and experience a boost drop to 16psi at red line.
thats fine, and its SSGOhans car and results that we are trying to replicate with mark and nicks car, 18 dropping to 16 (i have all daniels graphs) is fine but we are getting 18 dropping to 12 with the actuator that was supplied hence i asked mark to upgrade.
I understand it is never going to hold till redline with the 0.63 but the increase of boost from 12 to 16 with the bigger actuator could give us as 20-35rwkw.... a great outcome.
Hi Trent. you mean Ricks car? he's definently have the high pressure actautor, I tested it on front of him before putting it on. He's also got the wastegate controller installed, Have you had a play with it on the dyno? That will hold 18psi red line.
Also he's turbo is in a totally different profile to either Daniel or Mark. It will be the most responsive out of all 3, How ever marks should have the highest torque.
I will check mark's actuator and few other things this weekend.
Plus do you still remember that light blue R33 you workedon towards the end of last year? that guy's got exact high flow profile in .63 turbine a Marks with the same actuator. He's holding 21psi to red line. Did he came back after running into few trees? (he said he had an accident when I rang for some feedbacks.)
Its just strange same actautor on the same turbo gives all sort of results on the same type of engines.
Few photos added in modifying intercooler pipe to suit a BOV. Photo shown the driver side pipe that is connected to the outlet of the cooler.
Its a HPVA BOV. We make them as well.
As some of you've might seen. This is ATR43G4 in .82 turbine housing Running internally gate with high pressure actautor.
In generally you will find .82 turbine housing and high pressure actuators work pretty well on RB25dets. made 321rwkws@22psi.
so i have an r34 rb25det neo, and i want to upgrade the turbo.
I have all supporting mods to get to 270rwkw, but I'd rather have like 250 with better response. So can you recomend a turbo ATR43G2? or could i get that result with my stock turbo highflowed?
We can do a SS2 high flow to your stock turbo. which will make 260rwkws with stock standard response. Every thing bolts back on with no modifications required.
funny that the 3071 keeps pulling past 7k yet the others dont...
Please see this thread for which cars were selected etc:
http://www.skylinesaustralia.com/forums/Qu...urbo+comparison
Its far from a perfect graph. It took me a lot of time, feel free to make your own thats better. These are all real dyno graphs.
I just used it as a way to show the pre 3000rpm performance of the stock turbo.
I've high flowed few in 2860RS spec. and it was more responsive then stock.
SS2 is a T3x .63 rear running a 2871RS spec CHRA in 52T comp using Stock housing. will get full boost by 3000rpm and max about 260rwkws.
Also Waste gate lever controller for stock R33 turbo high flowed units. Controller is optional, and cost more to make.
(note: Wheel profile made to use with this type of turbine housing is different to standard high flowed units. Slightly more lag, lot more top end.)
how does mine compare to this Stao?
I see you have changed the position of the wastegate controller, much better :D
hello stao
ime interested in your atr43g3 with .82 rear for an rb25det r33, and also your atr43g2 with .82 rear what is the diff between the two. me chasing 280 300rwkw.
ive been looking at garretts gt3076r and cant decide between them or you. what would u have close to that
and also would a .63 rear be cappable of my power goal. and what sort of lag would i be looking at between the .63 and .82 rears, thanks.
We can supply all Garrett BB CHRA in what ever combinations you want.
The GT3076 56T running .82 housing with waste gate controller will get you about 300rwkws at 23psi. We can build this model based on a .82 T3 OEM bolton turbine housing with .60 Garrett anti surge comp housing and a big can actuator for $2200 including GST. All your stock lines fits. You see full boost about 4200RPMs with this model.
The sleeve bearing of above is ATR43G3. its about 200RPMs laggier, archives identical amount of power and power curve.
With .63 turbine housing we recommend a custom 3576 or 3582 profiled running .70 A/R comp. It can get you around 290rwkws with better response through gears.
what would the atr43g3 be like at 18 psi
and this is $1450 against $2200 and ile only lose 200rmp of lag.
is the afm the same diameter as the inlet. and u said i could achive my goal with one of these was that with .63 or .82 rear
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
