Both are pointless and shit ideas. I tried the half metal half stock(the bigger end). According to Tao, this is a loss of 65rwkw from back to back tests he done. I made 244rwkw. Add 60rwkw you get 304rwkw from the SS2. Ive got it sorted now, full 3" metal just need a retune.
would be interesting to see if the intake pipe really restricts that much power alone from a intake pipe change. awaits your results with anticipation.
if i had time and could weld, i'd make a bunch of these metal intake pipes for you rb20/25 brothers out there.
If it sucks shut it restricts it massively, if it doesn't suck shut then it is fine.
any exhaust/performance car shop will make you one and install it for $200 max anyway so I don't know why people bother assing around trying to make their own etc.
Hanaldo just paid $400 for his intake pipe..lolz. Or was it 300?
With fittings for the bov and pcv connections from the stock piping? I highly doubt it.
Would love to see someone make them with the two connections (pcv and bov) and have it hook up to the factory airbox. I would buy that.
Ron picked it on this one. Get the silicone intake off ebay. Then add metal. This stops the silicone sucking in. The silicone internal is bigger then the o d of the 3inch pipe. Fits stock airbox and has bov return etc
I doubt u will make 60rwkw+ from a less restrictive intake pipe, thats more power than a granny corolla puts out at the wheels, anyways we will await your after-tune results..
Dude they already done back to back tests. check:
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__860
http://www.skylinesaustralia.com/forums/topic/261613-hypergear-hiflow-service-continued/page__st__1120
Check index.
The silicone ones I have seen the fittings are way off the standard locations, plus the turbo end is only 2.5". I fitted it in my R34 and the pod filter would not fit in the engine bay with the afm and pod bolted to it lol. I bought it from 888Autobahn or something from ebay. He gave me a refund but didnt really give me a reason.
i did the rev210 mod on my GTT, the metal pipe collapsed. Ok for standard, not ok in a high-flow, higher temp situation.
Chasers made me up a full metal intake from airbox to turbo.
Haha don't tempt me if only I had time. I cant see your intake causing a restriction at all. Plus the straighter the pipe better dose/flutter sounds
If your pipe is sucking closed you will make that much extra power, if it isn't then it won't really help much.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
