That was a standard intake pipe with sleeve. Totally different to a 3inchmetal intake pipe with silicone joiners
Do you have one laying around? I'm interested of doing a back to back dyno testing using a PU .82 high flow. Would be interested to source some for high flow customers if they work, or at least can find out what they support up to.
Completely off the current topic, but is there known compatibility issues with the r33 gtst just jap racing split front/dump pipe fitting on a hi Kai high flowed r33 gtst turbo?
If so what's the issue and how can I get around it?
If the intake pipe sucked shut at full gas would the car go noticeably berserk because it's the equivalent of breathing through a straw instead of it's mouth?
I don't see how a metal intake pipe would make more power than a working rubber intake if they're the same sizes roughly.
What do you mean beserk? The car will be limited to the amount of air it can get throught the collapsed intake pipe. I used to have it and once it sucked shut the power line was just flat. On the road it just felt like a huge flat spot in power. Car still ran fine etc.
The engine completely dies, then it slowly opens up a bit then sucks shut again, basically feels like the engine has been shut off.
I thought the turbo is comming back for a ss1.5 upsize.
The main issues with intake restriction are that it can not supply enough air to the comp wheel, 2ndly that slows down the shaft speed making turbine wheel harder to turn, there for trapping combusted air inside combustion chamber causing detonations.
I'm still waiting for bit more feedbacks from couple of evaluation SS2 units at this stage. Will produce them when I have more solid results. For time been, 250~270rwkws mark use the SS1PU and 270~300rwkws mark use the G3.
There is also a prototype high flow from R33 21U turbo that Im working on and off for the time been. The goal is to duplicate G3's result while stay in factory turbo shells.
There is also a prototype high flow from R33 21U turbo that I’m working on and off for the time been. The goal is to duplicate G3's result while stay in factory turbo shells.
This is the best news ive heard in a while! keep up the good work on this idea :)
yeah it got sent back here for some reason??
i cant afford to get my turbo fixed now but when i have some spare cash il send it down again.
hi stao, what was the price on highflowing a set of r33 gtr turbos. want loads of response with around 400awhp
Yes can be done, cost $1700 for both turbos.
Also congratulation to customer whom won Vic hill clamb championship. That we built a custom turbo for his SR20det blue bird.
The JJR pipe is to close to the firewall and burns the Air-conditioning pipe. You get wet feet. The only way i got around it was to cut the pipe, and drill the hole back into it (was melted shut)
I have one on my car at the moment, and it hasn't done anything to my air con as yet I don't think.
I thought there was meant to be a problem with the wastegate not being able to open/close properly on the high flowed r33 gtst turbo because of the bit of metal which splits the flow?
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
