where does a stock R32 or R33 GTR intercooler sit in the graph between china spec and say PWR/ARC type coolers?
Does anyone use them on GTST cars?
Back say 5 years ago it was frequently used or GTR owners would say that up to about 280awkw the Stock coolers were still good.
I'm thinking of getting rid of the ARC return flow for an R32 GTR cooler.
Purely cause I want OEM Nissan Parts on it where I can.
Well guys on here are using them up to 400kw and not having problems so they are pretty dam good.
Did you even read my post? I am not running a atr43 G3, Im running the ancient hypergear turbo tr43i which the power is spot on to what stao predicted it would make at the time when I bought it. I was told to expect 260-270 mark on 98 so I have not bandaid fixed anything since I never had a heat soak problem from the beginning as continous runs on dyno whether 98 or e85 I didnt get massive power drops.
Thanks for your input but the post was directed at coppycutter.... Your results and methods are fine. Chill :)
I suppose I could try and get goodwill tuning, but if I were him running a business, I wouldn't expect to have to retune because a setup was poor, which Is more on the car owner for lack of research I guess. As for borrowing parts from forum members, I don't know anyone on the forum at a personal enough level to borrow a cooler and leave them stranded while I sort out my own issues
What I mean is, you ask the tuner can you come back with a new dump and cooler and he gives it a go. If it doesnt give INSTANT improvements that he sees worth while, you pay him for his time and not for the full retune (as he didnt do a full retune).
Then you continue on that road until he is satisfied you have fixed the issue. Once the car hits the rollers and seems to be 'fixed' he can then go hard and tune it for all its worth, and you pay the appropriate fee.
All im suggesting is that you protect yourself from the cost of a retune when it doesnt seem to have changed. Theres no point paying him to sit there for 5 hours going yep.... still the same....
i thought of going down this path, as i got access to a cheap R33 GTR core (currently running a no name hybrid style)
but atm, my core has been fine and there hasn't been any issues.
if i was bothered tho, i'd swap the cores over and get it back on the dyno for testing.
If you want to go plumback bov then the whole GTR cooler/bov/piping setup is actually a really nice solution.
The piping is huge though and really only suits a forward facing plenum (non-GReddy type, i.e. not going through battery tray).
Oh and the 32R cooler core is fkn heavy! but I'm pretty sure it took a hell of a lot of the impact in the accident :whistling:
Im running a nismo intank as my feed pump and the 044 from my surge but the results were the same when I just used the single nismo intank.
yeah, Im pretty sure even the stock pump is plenty good enough to supply a surge tank setup..
Yeah for a feed any pump will do for me it just turned out this way because previously was using just the nismo intank then later decided to add a surge tank.
1996 R33 GTS-t SII
Unopened motor
Stock plenum
Stock exhaust manifold
Stock BOV
Hypergear ATR43G3 internal wastegate
ViPec V44
HKS EVC-S boost controller
Nismo 550cc injectors
4in Aluminium Intake
4in K&N air filter
Greddy FMIC
Walbro intank 500hp pump
Splitfire coilpacks
NGK BKR7ES copper spark plugs, gapped 0.8mm
3in Bellmouth dump pipe
3in Decat pipe
3.5in exhaust, no mufflers
375rwhp on 20psi, fullboost by 4200rpm (sorry no dyno graph >_<)
Great, looks like you ended up making the 280rwkws.
FNT turbine update:
I've been working on a newer ATR43G3's rear housing for few weeks now and this new FNT turbine housing that suited better for the street:
Dyno tested today at Statu's brand new dyno room. :thumbsup:
(Pink line corrospond to reading above, The blue line was from a different turbo)
Compare to the older housing I've lost about 10KWs based on the same boost level, but much better response. How ever 20psi is about the max efficiency from this turbine housing, while the older .82 FNT housing was still making power at 24psi.
I've also fixed up my EBC (big thanks to Trent): Greedy Profect B. That worked like magic (with the 20psi actuator). Very steady boost control, worked better then the manual controller I've had.
I will be removing this turbo and evaluate some thing else. This turbine housing will be available for swap to any one that currently own a .82 version of the G3 for further evaluation and results. PM me if interested.
For those in WA or Perth with a Hypergear turbo, i would suggest taking it to Garage 101 to get it tuned.
Because?
How many hg turbos have they done?
Because?
Not sure how many they've done. But i found out about them through a guy who got good results from them, with an almost identical setup to mine (ATR43G3).
I've mainly had WA customers experiencing problems with tuning, which is also the first time it cames to my awareness as an issue. I've never thought the "tune" would make that much difference as most tuners I've used in Melbourne are good and getting close results.
Also make sure the car is running 100% before taking to the tuners, most of them would just chuck it on the dyno without knowing if there is an issue. becuase of that, figures could be way off the norm and possibly cause damanges to the engine.
FNT turbine update:
that looks nice and smooth...are u still using an adaptronic Stao?? Y not using its built in boost control??
Oh wait I see an afm so i guess not..I see you still have the Ex manifold though..hows that working out
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
