And let the holdups begin:
4 of the Nismo 555s I supplied to Racepace, aren't actually Nismo injectors...they just look exactly the same...except for a different spray pattern. I bought these second hand from a seller advertising them as Nismo 555s out of an SR20, then got them reconditioned / flow tested...so I've been ripped off :(
Racepace are reluctant to use them with the 2 x brand new Nismo 555s I bought from Nengun, due to different spray pattern, so I have to source 4 more Nismo 555s before they can get to tuning :(
A little useless telling you this now but had I known a month a go I would have sorted you out... I ended up using my 555s 'for the sake of future scope'.. Cars all done now :(
BOOYAH just found 4 x Nismo 555cc in my shipping container of race car parts. They must have been in our S15 tracker before we put 740cc in to run E85. Just dropped them down to Racepace and Chris said my car could be on the dyno by the end of the day or he might come in tomorrow to work on it...worst case scenario I should get it back Monday, pending any tuning issues.
Still reeling about paying good money for copies though...hopefully I can get a few hundred for them on eBay.
Bummer thats a pain though teething issues are to be expected..
Do they have the same looking nozzles ?
Edit..lol, I paid 100$ each for stock sr20 NA injectors advertised as 740 nismos..best mistake I ever made ;)
Bit of a cross post, from RB25 turbo upgrade thread, but I did promise Stao to post results a while back.
98 R34 GTT - Auto
Blitz return flow
Trust PE II
HKS pod + z32
3" Hard metal intake pipe
Hypergear ATR34 G3 0.82 rear
TurboSmart Eboost 2
TurboSmart FPR800
Walbro intank
Bosch ID 1000cc Inj
NGK BKR7ES copper spark plugs, gapped 0.8mm
MV Automatics Stage 2 kit - valve body + welsh plugs
Nistune
Running KU31 255/30/19 on the rears
A little box slip, which is why the rpm is out - redline set to 7k.
Cooler was a little heat soaked after 30 something runs, and tuner wanted to play with extra load points at the bottom to fix idling.
Could have pushed for 300@20psi, but it was overall too laggy to be my daily and tuner had concerns over bend shaft causing rear wheel to touch the housing.
Decided to ask Stao to resize from an ATR34G3 to an ATR34SS2 to improve response.
Since then there's been some box troubles, so have replaced the solenoids and upgraded 2nd gear to a billet servo.
New tune *hopefully* next week, will post results then.
Edit: Images fixed
Farrrrrrk :(
f**king scumbags man, it'd be so easy to con people too because side feed injectors all look the same! I bought these nearly 2 years ago so no hope of getting money back, the seller probably didn't even know they weren't genuine as he was selling them second hand himself.
Those reading is based on a half opened waste gate, the tuner must've unloaded too much tesion from the actuator extender, causing it stick open. If would be a very different end result if the actuator was adjusted correctly. Is the ss2 installed and running? Had a test drive on it yet?
Just went for a slow cruise in the car
Ran into some more trouble this afternoon
Started it and the water line opposite side to the manifold started spitting out water
Ended up being the washers I used were to big
The side closest to the manifold may or may not be leaking.
Pretty worried about it but I guess only time will tell
Way to hard to get to the washer now as everything is back together
Yeah I thought so, which is really annoying because the G3 may have been a better choice... Anyways it is installed and running, not tuned because 2nd gear locks into limp mode, solenoids should be here on Monday or Tuesday, then couple of hours for tune, will post up results.
Even in third with the bit of lag it's nice and boosty!
Question guys.
Can I chuck some gasket goop around this bolt
To stop it for leaking just in case
Or will that just do nothing
The engine side is a pain. You can put a very thin layer of silicon glue around the washers that are going in there. which works well.
Also the AFR in previous tune is all over the places, its leaning straight up after 6200RPMs. is it pinning up top? DVS should be able to touched it up or I guess he would erase it for a completely new tune.
I think you will end up making a bigger mess. I would just try to find the right size washer and do it properly. Mine eventually sealed without a washer, the coolant forms it's own seal, but I leaked a lot of coolant and made quite a mess before that happened. Take it from me, do it right the first time. The water lines are a bit easier to get back in once they have had time to get used to their new shape. It's not too bad a job.
Edited by Hanaldo
Here are my result of the G3 FNT
Havent seen any car that can match Stao's results on the same turbo so far, no matter how much everyone tries, I wonder why- they all read 10-30rwkw lower on average
Thats is because Stao's running lot more boost most of the time which really shows the advantage of a built motor plus the all the expansive supporting mods and he's only uses one of the top tuner in Australia.
He usually post result of a maxed out turbo, no one's crazy enough to run 24~28psi on a stock engine plus their tuners won't let. I hope he can post some results on 15~18psi based.
Edited by GeorgesR34
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
