Guys,
How about starting another thread "For Clutches" as this is starting to hijack the Hypergear Turbo thread.....
Dont get me wrong (its all interesting as I will need one soon so i am whatching what is said) but its getting a little off topic for poor Stao & his fantastic turbo's....
Just a heads up ok dont want to put any nose's out of joint so to speak....
Dazza
If Stao has an issue with it I'm sure he'd say so. He indexes all the pages in this thread so it's not like it's difficult to find the sections relevant to your interests. I think this is a pretty important part of the turbo selection process as people should know what works with what. I like that the threads, both Kando and HG take a focus on helping people with their whole setups instead of just focusing in the turbos. We're like macro communities :)
Its good to have documentation from all range of supporting mods working with the turbo. I will index them in the main page.
I've been taken some time off working on my electric turbo again. lol here are some latest updates:
The new charger runs of 44V 120AMP of power from a 2x 6S power source with RPM controller.
I've installed it on to a Daihatsu Sirion with a 3cyc 0.97L engine. This car makes from 0 to 100KMs in 21secs factory. lol
After appling the charger in 3rd gear full throttle it actually made the Speedo rising a tinny bit faster. There is a just noticeably acceleration gain with the charger is activated and not. I'm installing it on the R33 for dyno runs next weekend. hopefully making better result then the previous one.
Plus I'm working on a VNT .82 rear housing for the G3s hopefully getting SS1PU's response with 330rwkws top end.
Can this new VNT housing be made for external gate? I just purchased a wastegate and highmount so as discussed a month or so ago my turbo will be comming back to you soon.
Will try and get it off this weekend
Trying to decide if i should send you guys my stock rb25 turbo or buy one off you or buy a GTX30/76, chasing 400-450hp, what would you sell me? i would like too stick too Australian products.
Edited by 51NNA
The limit for a Bolton G3 on a stock exhaust manifold would be 400rwhp with proper mods on pump 98, unless if you are going for E85 then you can get that 450rwhp+ (abe's R33 358rwkws).
Or you can high mount It run external gate, which would be the best solution for the goal, and reduces the cost in building the turbo to just $1000. We also have a externally gated turbo called the SS3. That would reach you goal with possibly the best response.
Pump 98 results and details from that turbo is in page 120
It was a billet wheeled turbo based in a SS2 externally gated housing. It was very responsive how ever only worked well externally gated, internal gated version was about 30kws short. Its a very different turbo to the G3, how ever you can run that rear housing with it and the results won't be far off.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
