The current one is capable of 330rwkws. I'm looking to trade that 30kws for roughly 300rpms of response making full boost of 20psi by 3900 Rpm instead of current 4200 rpm.
I'll finally be buying a turbo off you around July so ill see where your at with FNT and VNT designs of the G3 then. VNT sounds like it will be great if its a reality that soon
After studying motion of the vnt turbine setup I'm wondering if it actually creep heat when the nozzles directs in opposing direction. Appears the nozzle arrangement needs to be reset from scratch for it to work. Or for what I want it to do.
I've contacted Matt to see if he might know what could cause the corruption, as everything was perfect a month a go when I last drove the car.
There's Nistune documentation that talks about ECU corruption and how it can be caused. Worth a read. A loose Nistune board is just one path to corruption.
Ah great, do you know which of the documents it's in? I've contacted Matt about it but he hasn't replied yet.
Thing is, I didn't touch anything related to the ECU, and it was perfect when I drove it in. Surely it has to be something related to my messing around with it all, it's not just coincidence?
So this is going to take a while?
http://nistune.com/docs/NIStune_Diagnostics_Document.pdf
Thanks for that mate.
Makes me wonder whether the message was passed on that my ECU has a Stagea image in it. I forgot to tell Sean when I dropped the car off, but I phoned up and let them know, the bloke was confused but he said he would write it down. Now I wonder whether or not he told Sean before he started trying to tune it, if he tried to use the R34 image with my ECU then it wouldn't have worked. I'll have to give them a call tomorrow morning and get hold of Sean himself.
Edited by Hanaldo
You might be able to get away with editing the fuel & ignition maps (and most other normal tables and scalars) in the Stagea image using the R34 address file, because I've been doing essentially that myself over the last few days. Load up the Stagea address file, then the bin file for what's in my ECU, then an R34 bin as comparison, and looking to see where the differences are. As you'd expect, the two ECUs are essentially the same. Same ECU, same engine. Just a few differences in the ABS/TCS department.
But....because you can do that, it might be very easy for the tuner to use an R34 address file, load up an R34 bin file, then sync from the ECU and or/ sync to the ECU and perhaps cause havoc. Just because there are some differences.
depending on how much problems I might encounter. would be couple of month at least.
Sweet as. ill keep an eye out
I'm waiting till July now till I get something so if its not far off by then I might just wait.
Sounds like it will be impressive :)
This assembly should have some effects, With the device engaged the turbo gains faster response how ever the engine pins up top, with it disengaged the motor picks up 8 degrees of timing up top but loses big chunk of power band down low. So I want it to be engaged till about 20psi then slowly released after that point to gain the top end timing. That way we should have fat power band from start to end.
Yeh well when Matt reprogrammed my board with the Stagea image, he was able to upload my current tune so I could just plug it back in and it was like nothing had changed. Except the misfire at about 5000rpm from the ECU pulling timing was gone.
But if the message hasn't been passed onto my tuner and he is trying to start with the R34 address file and then sync the bin file from the ECU, it wouldn't work as you said. But then I have no idea what he meant when he said it looks like it has earthed out, so I'm not sure.
Your the man stao!
I'm keen to seen how this turns out. I have 2 friends who just acquired RB25s and hopefully will be looking for killer upgrades in time for production on these.
Hello, ive got a r33 s2 and wondering what is your best hi-flow turbo for response, only looking to make 220-250rwkw, stock internals with associated mods. Its a daily and would be looking to run between 10-14psi max.
cheers
Standard high flow would be suitable for your applications. I'm generally seeing around 240rwkws with option, how ever I'm recently seening some 260rwkws results based on 15psi from Toshi's remaps using stock injectors, afm and ecu.
So for your goal, get the standard high flow, then pm toshi for ecu flash and that should archeive it.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
