When I took off I heard this voice say "your shifting to early wind the gears out"
Wonder who put that in my head was huh Jez
I admit it im a bad influence. But i am a good teacher, atleast u know when to change gears now u pussy :P
When it stops making power? hahaha at 300rwkw, I stop changing gears by the RPM, kinda have to play it by ear....literally. Far too focussed on the road.
He was changing at 5500 or some pussy rpm
I admit it im a bad influence...
Not really, I remember when u were tuning my car u kept telling me to take it easy n slow down as i was revving the sh** outa all gears so u cud tune the upper rpm points too.. Ur kinda good influence I reckon..
Docile every-day driving I usually change around 4000rpm, but the few select sections in this every day driving I give it what for as I would on a weekend - ~7000rpm shifts, not letting revs drop below 3500. hahaha though this is rare :(
Docile every-day driving I usually change around 2000rpm, but the few select sections in this every day driving I give it what for as I would on a weekend - ~2500rpm shifts, :(
because Diesel Van
Yeh the ss turbo's build boost faster but can't seem to hold it as well uptop. I had one of staos wastegate mods on initially but the boost wouldn't go below 20+ psi...
I'll wait for Jez to post the overlay graphs, but IMO the SS1PU comes on faster and has a better top end. Maybe you're thinking of the SS1?
I wasnt really expecting to get a result similar to an ss1pu, they are like $700 more and are a superior turbo. You would expect them to outperform a standard hi flow easily.
Im happy with the result, but if I ever get over this setup (highly doubt I will for a while) theres always the option to sell up and go bigger with something like gtx3076 later on if I wanna chase a larger number.
Edited by Mitcho_7
Haha ur a hoon
Had to chime in Jez, pot calling the kettle black anyone.............. :) :)
You've driven my car so I have first hand experience lol ;)
Ive never seen my semis so "ungrippy" heheheheee
because Diesel Van
hahaha yes :P though I'd say about 500rpm more than what you suggested. 2nd - 5th are all pretty long gears, and I've found there's really no need to wind it past 3000rpm in any gear.
Lmao Dave i have no idea what u mean :P
