How does the wastegate open in that housing, is there enough clearance?
Its got 42mm of clearance inside the casing. thats far more then what the actuator can travel, won't case any issues.
Bolted up my SS2 today. Didn't need to bend water lines. Nothing fouled. Oil drain fitted. Not sure if it was made to fit perfect or because it had a highflow previously it had already been modified.
Can't wait to kick it in the guts:)
You lucky son of a....
I am so jealous of your simple install haha
Can't wait to see the power
The 350rwkws was made by a G2.5 in a type B rear housing on E85 internally gated. The G3 on type A internally gated housing made 358rwkws with 7 degrees regarded timing in fear of bending con-roads. It should be sitting around the 390rwkws mark with time added.
Now it is:
With all broken studs removed of course.
2ndly before installation I found the actuator had been short lengthen to lower boost. Doing so leaves the wastegate unsealed causing massive amount of lag. And that is a lag caused by negligence. It must be held shut and loaded as photo shown on the right, do contact me for a lower psi actuator if lower boost is preferred for what ever reason, but don't unload the supplied actuator, it does not mean the same thing.
I will ask the customer tonight if he unwound the preload when he fitted it years ago.
So did u replace the entire rear housing? It looks like a different wastegate setup or is the picture mirrored
Hey Stao, what size banjo bolts do you use on your cores? I've just been looking through the HKS manual for my turbo and looks like mine are all M14 banjo bolts, hoping when I buy a turbo off you after my holidays I can simply unbolt mine and bolt yours on and just screw everything in
Will this be possible or will I just need to get an oil/water line kit off you?
that was the old housing been sand blasted, cleaned and reworked to Type B rear.
The picture must be mirrored then because the flapper arm is from a different angle and so is the t3 flange.
I asked him and he said he unloaded it as he asked for the 14psi actuator but got the 20. This car wasnt laggy for the setup he had.
I didnt notice that before, but yeh when you look at it everything is opposite haha
This seems to happen to everyone...
Edited by Mitcho_7
Picked up my ATR43SS2 with .82 type B rear housing up off stao on monday XP Cant wait 2 get it installed on my 33 nd see how much power it makes..
I've fixed the photos. appears on the same way now. With the gate loaded and shut it should've pickedup another 200RPMs of response. Its been loaded now and hopefully there are some good tuners in NT.
Be good to see another result :) I'm hoping to lift my engine in mid next week. What actuator did you get?
There is a newer type of comp wheel been developed for the SS2 that weights about 25% less then the current SS2 billet wheel. (its virtually feels nothing on hand, less weight then the Plastic OEM comp wheel). I think Trent's is getting his dyno together next week and I'm testing that very soon. So I suggest to hold on to your SS2 units to have that comp wheel updated free of charge.
You have my attention. Looking forward to checking it out. Which housing result will you be comparing it against?
you also have my attention, will you be testing it with a 0.63 rear housing or 0.82 housing? Im yet to put my SS2 in the car yet so i will wait to see if the gains are significant. But keen to get a Lighter comp wheel
This is a high flow that I've done for a set of Toyota supra with the SS1.5 CHRA. Come out pretty good. photos:
By specifications those two should be enough to flow 500rwkw+. Will post results once the customer get his car tuned.
Also this are stainless steel 3inch metal induction pipe made by Abe for R32/R33/R34 high flowed turbochargers. RRP is $200, or $150 with any turbocharger services purchased. PM if any one's interested.
These intakes can come with both recirc ports?
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
